Old 05-28-2012, 02:38 PM
Zak650 Zak650 is offline
Zak650 is on a distinguished road
Default Re: Rick's 1973 VW Super Beetle build
I'm thinking of turning an aluminum flywheel and then having it hard anodized for the clutch friction area since it's main purpose is to make shifting more "regular" and the slipping action isn't needed at all. It's either that or go clutchless.
Zak
Old 05-28-2012, 04:51 PM
ricklearned's Avatar
ricklearned ricklearned is offline
ricklearned is on a distinguished road
Originally Posted by clonezero View Post
Why did you go with a lightened flywheel? On my bug I had the flywheel and pressure plate ballanced. But not lightened. Was this a mistake?
No, it wasn't a mistake. I had mine balanced also. I didn't want any vibration and I expect to take the motor to higher revs than the gas engine. According to the previous poster, I also saved the equivalent of 60lbs of body weight. I think it has something to do with not having to overcome the inertia of the flywheel when accelerating. The flywheel serves a purpose on an ICE but for an electric drive car it's only purpose is for the clutch.
My 1973 VW Super Beetle Thread
http://www.diyelectriccar.com/forums...ild-74500.html
Old 05-28-2012, 05:57 PM
Weight should really be considered, think of it as replacing the weight with additional batteries, better acceleration, longer range.
A few examples:
Starter motor 10 lbs
Spare tire 30 lbs
flywheel 13 lbs
rear seat 27 lbs
gas tank 20 lbs
Basically about 100 lbs in just a few items, it's all weight you don't have to drag up a hill or get moving from a dead stop. These items are about the same as 8 Calb180 cells.
Old 05-29-2012, 12:05 AM
Here is the clutch plate I purchased. It has hardened and longer splines so I won't have the problem Corbin experienced. I also got a Kennedy 2000lb pressure plate
Old 05-29-2012, 08:40 AM
onegreenev's Avatar
onegreenev onegreenev is online now
onegreenev is on a distinguished road
I would not worry about a few extra pounds unless your going to RACE your car and really need that extra 1/100th of a second for the win. Really, what's that few extra pounds going to actually do to your speed and distance?
Change comes, one conversion at a time.
http://onegreenev.blogspot.com/
Old 05-29-2012, 12:54 PM
corbin's Avatar
corbin corbin is offline
corbin is on a distinguished road
cool - where did you get that plate from?
corbin
The Plug Bug Project:
http://www.corbinstreehouse.com/blog/plug-bug/
Old 05-29-2012, 07:50 PM
corbin
I got it from Scat, which is in my neighborhood, so I will called it.
http://www.scatvw.com/
Hopefully you got yours back together.
Old 06-04-2012, 09:58 PM
I am a little behind in posting. After getting the adapter mounted to my motor I realized that the clutch return spring was broken so the next day I repaired that and mounted the motor to the transmission. Here is a picture of it just before I put it in the car.
I have since mounted the controller and begun wiring.
Old 06-06-2012, 06:21 PM
winzeracer's Avatar
winzeracer winzeracer is offline
winzeracer is on a distinguished road
Looks like it is coming along. You are right about the inertia of the flywheel, less energy required to rotate the lighter flywheel which results in more energy transfered to the wheels. I am just about to take my final on rotational dynamics.
_______________________________________
Brock
www.winzeracer.com
Old 06-06-2012, 09:58 PM
Good luck on your final.
Come down to Hermosa Beach sometime and see my bug.
