DIY Electric Car Forums > EV Conversions and Builds > Electric Motors
Old 04-11-2012, 01:24 PM
franky975 franky975 is offline
franky975 is on a distinguished road
Default Re: Using a forklift motor, and choosing a good one
Wow. Thank you all of your replies. I have seen all of these motors on ebay except the milkfloater motor. My donor would be something from a suzuki swift(geo metro) up to ford focus sized car whatever come up cheap enough in reasonable condition. One of these motors is too big(heavy) for the size of mi (planed) car other one has 80v rated voltage others has 3-8kw output what may not be enough to maintain 50 mph in a such car. I would use it to go to work and back what is a 10 miles round trip and on my way to home i may use highway hence the speed demand (only 3.5 miles). Ocassionaly on weekends would have to do 30 miles on one charge. My plan is 120v lead acid pack so i think a 48v 10kw motor on 120v would do 25kw=34bhp what would be enough to accelerate 2200lb of metal(and me). Does it make sense or i am wrong?
Who sells the linde r14 drive motor has the pump motor available as well. The specs are 48v , 230 amp, 2900 rpm, 90 kilowatt(?). Is it any good or should i go for a bigger one?
Thanks. Franky.
Old 04-11-2012, 02:07 PM
green caveman green caveman is offline
green caveman is on a distinguished road
Off-topic for this thread, but don't buy batteries until the very end of the conversion and when you do, take a very close look at the advantages of Lithium batteries (which, hopefully, by then will have dropped even further in price).
There are many threads on this topic. Short summary. Although Lithiums are a higher initial investment (say twice as much) the general thought is that over the long term they are more cost effective (more charge cycles). They're easier to mount - the physical size is smaller. The lower weight makes for a car that "feels" much better.
Old 04-11-2012, 09:00 PM
wildcat_1967 wildcat_1967 is offline
wildcat_1967 is on a distinguished road
jrp3, that does indeed look like them.
Old 04-11-2012, 09:07 PM
Originally Posted by JRP3 View Post
yes that looks like them JRP3.
Scott.
Old 04-12-2012, 01:56 AM
Woodsmith's Avatar
Woodsmith Woodsmith is offline
Spam Busting Admin
Woodsmith will become famous soon enough
Thanks. Franky.
One initial indicator of size would be the physical dimensions of the motor, about 9" diameter would be about the right starting point for your conversion. Much smaller and it won't be powerful enough, much bigger and it will be heavy and not spin fast enough.
The specs on the 48V pump motor you describe sounds good but is more likely 9.0kW. That would be the sort of spec you could look for. Drive motors are better to go for as they have a higher duty cycle rating, usually 1 hour as opposed to pumps which are maybe 5 minutes, at full rated power. Also pump motors tend to have female shafts which are really difficult to use in a conversion.
Old 04-12-2012, 06:00 AM
Yabert's Avatar
Yabert Yabert is offline
Yabert is on a distinguished road
Roughly, you are right. 25 Kw is a good amount of power to move a small car. And you can obtain much more power for few sec. during an acceleration.
But the main problem remain. The power of a pump motor is only rated for 5 min... after this time, it will overheat.
Try to find a motor with one hour rated.
My Smart Fortwo high power!
http://www.diyelectriccar.com/forums...ion-51472.html
Old 04-12-2012, 03:26 PM
alvin's Avatar
alvin alvin is online now
alvin is on a distinguished road
Send a message via AIM to alvin
Hi All
I am going to convert an MGB. Found them in a barn in Feb. I have an 8" pump motor that was on the forklift I got the 11" motor for the Ranger conversion.
Anyway it is a GE 20% duty 7.4 KW 280 amps. The one with the funny looking extensions on the drive end.
I put it in the car to test different pack voltages. 72,96 and 120 volt.
120 gives plenty of speed. I put a fan to blow air through it . The motor temp has only gotten up to 90 F. so far. I have only driven it a few miles at a time.
The question is to maintain speed the motor draws about 160 amps, bat amps about 80. In the ranger with 11" motor it only takes half the motor amps to do that. Is this a difference because of the motor size or is it just not enough motor.
Thanks Alvin
Old 04-13-2012, 08:56 AM
Arlo Arlo is offline
Arlo is on a distinguished road
Whats a rule for max armature rpm for the different dia motors?
Worlds fastest electric bmx? http://www.youtube.com/watch?v=HSh8uGcFpJs
Yamaha E-YSR with 15kw DIY BLDC controller!
http://www.youtube.com/watch?v=91pGd...6Y37xYFFPRdPhw
Old 04-20-2012, 11:42 PM
salsmeyer salsmeyer is offline
salsmeyer is on a distinguished road
Greetings: This is a wonderful thread! I bought this Allis-Chalmers motor 28 years ago and now ready to convert my '82 S10. I'm planning to use Lithium batteries and keep the weight down where possible (motor weighs 200 plus).
Motor specs:
7HP 180 amps 840 rpm with open perf. covers
4.5HP 120 amps 970 rpm with solid covers
36 volts series wound
serv.factor: 1.0
1 hour duty
deg. C. rise winding: 115
deg. C. rise comm.: 130
Ser.# 7-6328-17266-1-67
57 comm bars (near as I could count)
insulation class: F
The brushes and comm looks good with little wear, inside of motor is clean, I have the gear for the taper shaft. What is a safe voltage? (will fan cool if necessary) What would be a good controller? Is this a good motor for the S10? Any and all advice is welcome.
Old 04-20-2012, 11:52 PM
I forgot to put the size of the Allis-Chalmers motor: 11.5" dia 16" long
