DIY Electric Car Forums > Marketplace > Classifieds
Old 07-17-2012, 12:31 AM
Tedktis Tedktis is offline
Tedktis is an unknown quantity at this point
Default Wanted!
WANTED: Liquid cooling system for Zilla 1k, 600V 2/0 wire, charger box (to fit Zivan NG3), Controller box (that will fit Zilla, main fuse, contactor, etc), batteries (Have quotes for $125 @ 100ah shipped w/busbars/Bestgo from Carl at electriccarpartscompany, 2 yr warranty)
Old 07-18-2012, 08:58 AM
dtbaker's Avatar
dtbaker dtbaker is offline
dtbaker is on a distinguished road
Default Re: Wanted!
two places I would suggest shopping are EVolveElectrics.com and kta-ev.com based on personal positive experiences with them both. for batteries I would go direct with Keegan at calibpower.com
Dan
http://www.envirokarma.org/ev - '97 Suzuki Swift
http://www.envirokarma.org/ev2_mx5e - '94 Mazda MX5 Miata
Old 07-18-2012, 09:11 AM
Default Re: Wanted!
Thank you!
Old 07-18-2012, 09:19 AM
dtbaker's Avatar
Default Re: Wanted!
Originally Posted by Tedktis View Post
Thank you!
sure....
by the way, you probably won't find a 'slap switch' handling 144v and 500+amps. One way to handle it is to run a choke cable thru firewall, and attach to your main circuit breaker pull.
I have some pix of what I did on my website, but other people have done it different ways.....
Dan
Old 07-23-2012, 11:42 PM
Default Re: Wanted!
sure....
That sounds like a great solution What volt/amp circuit breaker do you recommend for a 144V Wap9 with 1k Zilla? Can I just use a Siemens from Home Depot or do I need to special order it. We are installing a 240 V 15 amp breaker and receptacle to power my air compressor on my circuit breaker box, so I figured maybe they have one that could handle the amps for my EV for a maintenance or emergency disconnect.?
Old 07-24-2012, 06:58 AM
dtbaker's Avatar
Default Re: Wanted!
you CANNOT just use a 240v circuit breaker from home depot... those are for AC, and unlikely to function if the need arose to open the circuit while under load. DC power is much harder to interrupt, and the circuit breakers are quite different with stronger springs, larger gaps and magnetic blowouts to stop arcing.
read thru the sticky thread
http://www.diyelectriccar.com/forums...off-25318.html
consider buying a big fat GE, or using a gang of the AirPax available from one of our dependable EV retailers like kta-ev.com or EVolveElectrics.com
all builds should include a big fat Feraz fuse mid-pack, a circuit breaker with manual pull added, and fuses for everything on the 12v side as well as an inertia switch (mounted vertically) interrupt on your 'key on' 12v power to controller.
Dan
Old 07-24-2012, 07:25 AM
Default Re: Wanted!
I was just reading that topic the other day! lol. I will go back and re-read it. I did find these at KTA, but I have a 1k controller, so would the lower amps work? I don't see anything near 1k? http://www.kta-ev.com/SearchResults....ircuit+breaker
Old 07-26-2012, 06:23 PM
Default Re: Wanted!
Folks at KTA were great! Got an airpaxand PB-6.
