Old 07-25-2012, 01:56 AM
LSB LSB is offline
LSB is on a distinguished road
Default Factory Five Project 818 4wd EV
Greetings Folks,
Long time lurker, first time poster, due to my humble request for help from your great community.
I have a 2007 Subaru WRX sti which my wife recently rolled into a ditch. I went to Google to help me come up with an idea to salvage what money I could from this catastrophe.
I stumbled upon this kit car
http://www.factoryfive.com/kits/project-818/
This mid-engined, rear-wheel drive layout leaves ample room around the front axle for an electric motor/controller/battery setup.
GOAL
600+ HP in a <1000kg vehicle designed to optimize 1/4 mile Drag time.
(400 from combustion engine + 200 from electric)
After researching many types of electric motor capable of delivering the desired 200HP of electric power needed to reach this goal I have come up with some questions I havent solved.
Due to the application of the electric motor, a long range will not be required.
The first question is: If using Li ion batteries, what would be the estimated minimum weight of the battery array required to power a capable electric motor to 200HP
Secondly I am not sure which of the popular motor designs would best suit my application. I am interested in installing the best technology available to reach my weight/power goals.
eg. will an ac asyncronous motor handle that power?
Will a bldc setup like the scott drive be able to stay under the weight limit?
The initial weight of the car is 818kg, leaving 182kg to play with....
Old 07-25-2012, 04:09 AM
jk1981 jk1981 is offline
jk1981 is on a distinguished road
Default Re: Factory Five Project 818 4wd EV
25-30kg of high power (50C) Lipo is about as light as you can realistically go for a 200Hp capable pack and that will deliver for about 1 minute (though rated for continuous 50C discharge they're unlikely to actually deliver that for 1min without something overheating). Pack life will likely be in the 10s not 100s of cycles if you push it that hard!
There's no point in going for top of the range high tech motor/control for this sort of job, you might as well get something that can take the power for short bursts without cooking and is simple/robust. Efficiency is less important than ability to handle big overloads for 10-12 seconds. Series DC might be the best bet since big power controllers are relatively cheap. Still, it's not going to be simple once you start looking at gearing, diffs etc. Two small motors, one per wheel might be a relatively neat solution eliminating the diff and offering the possibility of series/parallel switching to introduce some electrical 'gearing'.
Personally I'd go the other way: Sell the Scoobie motor, keep the weight down, install a big power (200-300kW), low-medium energy (maybe 5-6kWH, 50-60kg Lipo) electrical system with a very small motorcycle ICE providing maybe 10-15Hp of parallel hybrid cruise power. That way you get good fuel efficiency, normal range and very good peak performance.
Or just build it with simple Scoobie power and enjoy it
Old 07-25-2012, 09:52 AM
dougingraham's Avatar
dougingraham dougingraham is offline
dougingraham is on a distinguished road
I looked at this when it was in the contest stage. I thought it would make a good roller for a conversion. I wasn't thinking about augmenting the ICE with electric. My own preference would be to just make it a rear drive EV. It is so light that it will make an excellent EV. However here are my thoughts on the electric portion of your idea.
A single Netgain WarP9 at 1200 amps and 192 volts will be about 65% efficient. This would be 309 input horsepower and about 200 HP output. It can do this for at least 10 seconds, maybe 20. To get 192 volts after sag you would need around 256 volts so a pack of 80 LiFe type cells or a pack of 70 LiCo or LiMn configured with enough guts to do the job. Using A123 cells this means an 80S3P pack. This would weigh 119kg (262lbs) for just the cells. Using the 6AH Haiyin cells would require something like a 70S3P arrangment. This would weigh 36kg (79lbs) for just the cells. You would need to use a Netgain Warp drive controller or a Zilla 2K to reach these power levels. (Or a Soliton Shiva which would be overkill.)
Haiyin Batteries 79+ lbs.
WarP9 156lbs.
Netgain Controller 16.5lbs.
Total 252+lbs.
Additionally you will need a transaxle that can handle 200hp with an appropriate final drive ratio.
If you don't want a transmission on the electric portion of the drive system you need to pick an appropriate reduction ratio. Knowing what this would be has too many unknowns. It would be something around a 3.5:1 final drive ratio. You would need to tweak it in at the track.
Doug Ingraham
Rapid City, SD
1985 Mazda RX-7 GSL (1400+ EV miles)
Now on the road but still under construction.
Old 07-25-2012, 06:35 PM
LSB LSB is offline
This is an excellent idea for an 818 build if you didnt have an sti and started from scratch because the end result for the cost of the build would be phenomenal.
With a 15kw ICE and high powered netgain you would have a car that would equal the standard build in power, weight and range without using a drop of dirty fuel. And all for maybe a 15k premium, taking the build cost to around 30k.
For me, the loss I would take from selling the unneeded parts from my car would be too great. The motor, although on stock internals is very high output and I consider a total weight of 2200ish pounds is still very lightweight for a hybrid, or any performance car for that matter.
Due to the info I gathered from the advice you gave I think the scope of the project can be extended somewhat.....
The current estimate of weight distribution is 38/62 meaning that the front has 200kg less on it.
Going the netgain 9" route with a decent controller etc will leave plenty of room for battery weight while being able to maintain a 50/50 weight distribution.
If the Subaru motor output is increased to 500hp through a $6000 turbo and computer system upgrade I cab purchase, with the 300+hp input of the netgain we would have a p2w ratio of 800hp per tonne for acceleration/top speed purposes.
If you then add in the instant torque characteristics of the Electric motor, you will be able to eliminate wheelspin at launch. Being able to get that much power to ground at launch will leave any supercar for dead.
The Lambo Aventador has a p2w of 400hp per tonne, 4wd and sophisticated launch control and completes the 1/4 in 10 odd seconds.
Depending on proper calculations, the battery pack could weigh as much as 90kg while delivering this performance.
If you chose to drive only the electric motor you could still commute on a day to day basis (50km max range?) for the running cost of a chevy volt.
Start the ICE and the car's acceleration potential exceeds any other car on the road.
The first orders are expected to be available "Before Autum" according to factory five which leaves plenty of time to agonize over final decisions and design front axle setup...
Old 07-25-2012, 06:50 PM
LSB LSB is offline
WarP9 156lbs.
Total 252+lbs.
Thank you so very much, this is exactly the type of info I was hoping for!
In respect to the electric motor drive setup, my thoughts are this. Because the electrical system willl only be able to output maximum torque for a short period of time, I feel my best approach is to use a 'no transmission' design with a final drive ratio that with allow the motor to power the car to around 170 km/h(limit of 3rd gear).
This should allow a drive ratio that will really pull off the line which is needed to assist the ICE to get all of its power to the ground off the mark, while keeping weight and moving parts to a minimum.
After researching more I found that this design (called Heavy Hybrid?) has been around for a while in motorsports.
The 2011-2012 Le Mans winning Audi A18 drives the front wheels with Electric motor and uses kinetic force to charge the batteries.
Porsche 918 spyder being released soon also used this concept of 4wd.
Im sure you guys know that though. I am always a little slow.
Old 07-25-2012, 07:51 PM
Joey's Avatar
Joey Joey is offline
Joey is on a distinguished road
Whatever you decide on, please post lots of pictures of your build. This has potential to be really cool.
Old 07-25-2012, 10:32 PM
LSB LSB is offline
Managed to find some pics that may be of interest.
This is the Porsche 918 drivetrain design in top down:
And for comparison's sake, I sourced a top down view of the project 818 and roughly estimated where a netgain warp 9 would fit. Bit worried about fitting 192 batteries in...
Is it worth posting other views of the 818 to give some notion of whether this will even be viable due to size constraints?
This option is obviously direct drive with a fixed ratio, I'm not sure if there is any other method that would fit in.......
Old 07-25-2012, 10:41 PM
LSB LSB is offline
Old 07-26-2012, 04:22 AM
You'll not satisfactorily be able to exploit the Regenerative Braking potential using the DC series motor, I suggested that because this appeared to be a project focused on using some bits you already had plus minimal spend to build a drag car.
Also, the sketch you posted has no option for a differential and you'll need to ensure whatever motor you fit can physically hold together at Vmax even if it has long since given up generating any torque. Looking at the CAD rendering it's not very clear exactly where the front shock absorber mounts but since it appears to clash with the (not shown) track control arm I can only assume it's mounted further rearward than it appears where the front CV will need to be <edit> Looks from the plan view like there might be room </edit>. There's also a fair bit of triangulation in the way of your potential driveshaft runs.
If you're willing to spend some more serious money on this It might be worth looking at high performance motorcycle hub motors. Using two gets away from the diff problem, they're much lighter than a 9" DC*, the big ones used (modified) for racing can probably handle around 80kW peak, they're generally AC so open up regen braking possibilities and they're wound for direct drive at very roughly the speeds you're looking at. However, you'd need to make sure the controller and battery could not be damaged by excess back emf at Vmax on ICE power alone. If you're looking at 400+ HP that's going to be what, 160mph+? Two big AC inverter drives wont be cheap though.
*the downside to light weight is less overload capability.
Your battery volume won't be huge, I suspect you could slot a lot of it into a 'transmission tunnel' box between the legs of the passenger and driver which is low and close to the desired COG.
The other thing to look at is how much traction will you have. The COG should be fairly low with the flat Scoobie motor and no roof but the weight transfer rearwards is still going to be dramatic with 400 HP+ launching you forwards. I doubt trying to push another 200HP out through the front wheels will do much for you until you're in 2nd or 3rd besides generate smoke.
It has potential to be very cool but I still think I'd go one way or the other: Aim to get the high performance from the ICE OR the electric, not both. It's your project though, I'm sure there are solutions to all the problems so it'll be cool to watch
jk
Old 07-26-2012, 07:44 PM
LSB LSB is offline
You'll not satisfactorily be able to exploit the regenerative braking potential using the DC series motor, I suggested that because this appeared to be a project focused on using some bits you already had plus minimal spend to build a drag car.
My initial scope was for a streetable drag car, but I had overestimated the weight of batteries needed, meaning the scope can be broadened.
With respect to the DC motor, the main attributes are the overload capacity and the price which are both relevant. The downsides are very significant too though, including no regen braking.
This shot gives a better idea on an actual running car of where the clash points are. I found it in this testing video
http://www.youtube.com/watch?v=uN_jV...eature=related
The problem I initially conceive with hub motors is the unsprung weight they add. Also the motors will be much more susceptible to the elements and the disc brake setup is also an obstacle.
The advantage is that more weight on the wheel=more grip in a drag race as well as the lightweight setup.
I just think that the unsprung weight issue and the other complications that are connected to that are just too big a hurdle to choose this method.
In respect to traction, it is the main reason i chose the 4wd EV setup. It is of the utmost importance that the front wheels can be driven past the point of traction otherwise maximum potential hasnt been reached.
How much grip there will be and how to adjust both motor's output accordingly will be a trial and error thing. There will definately be much more grip than leaving the car RWD.
Another thing that is exciting about this setup is the manual gearbox. While the ICE transmission is disengaged during gear changing, the electric motor is still pulling.
