Originally Posted by monkmonkey
That 500 amp fuse on the left side is blown, which is why the contactor won't work.
How do you know the 500A fuse is blown? If it is blown, why did it blow? Without knowing why it blew, you should not simply replace it with a new one. Assuming it is blown, you can trace out and track down a short if that was the cause. Correct the issue and then replace the fuse.
And why would the blown fuse interfere with the contactor working? Hint: It does not.
Will any 500 amp fuse work that will fit or is there a certain type?
Fuses have ratings, and there are reasons for those ratings. I kind of doubt that fuse which is in there meets the requirements. It does not instill me with confidence, similar to my opinion of the workmanship of the entire installation. Many fuses having that form factor carry a 32 volt rating.
So, I recommend a proper fuse rated for at least 100 Volts DC and 400 Amps.
