Originally Posted by Billzilla
First post, be kind.
I'll try. At least I'll try to numb you down so you won't feel the killing blow when it comes.
but one idea was to use something like 20 lithium batteries
Lithium has extremely low internal impedance. This matters in a very big way since a small mistake will make them turn on their master in an instant. Not like lead-acid that tends to be very forgiving, at least compared to Lithium.
and have a controller as simple as a potentiometer connected to the throttle pedal
There's nothing simple over that, trust me. We spent quite some time just fine tuning the function of a potentiometer controlling a motor, it's probably a lot more tricky than you expect.
and as more throttle is applied it turns on solid-state relays in turn.
First problem: The Solid State Relays you've picked are made for AC. They won't work with DC. See? Already not so simple.
20 steps of throttle is plenty enough for such a car.
Errr. No.
Don't expect an EV to behave as you want it to. The motor current will depend on RPM, motor voltage, temperature, what granny had for breakfast and the chaos butterflies on the other side of the world. Trying to control motor current with a bunch of relays will best case lead to seriously crappy performance and worst case a burning wreck.
There's been a bunch people here in the forum that apparently has thought "How hard can it be?" and gone DIY-frenzy on the controller building. A few has succeeded but in most cases there's either reports of "setbacks" or "catastrophes" if they bother at all to report back when the controller went 4:th of July on them.
Even those that HAS succeeded has found out the hard way that it IS hard (especially if you want more than mediocre commuting performance) and I don't remember how many transistors Paul blew up before he got Revolt running. Come to think of it, I don't even remember how many transistors we have blown up in the process but it took a while before we worked out all the kinks of the S1.
Going for a relay layout might sound like it'd be simpler, but I doubt it. Long story short EVs didn't get useful performance until Lithium batteries and transistor based controllers. There has been people racing with relays but I doubt any of them used Lithium since you probably pretty much need the high input resistance of lead-acid to not blow the contactors up.
The problem with that is we'd need a DC brushed motor and from what little I know they aren't as light or efficient as a brushless motor.
Um. I'd want a reference for that claim.
AFAIK all drag racing nuts still run brushed DC because it's more power per kilo than anything else. Efficiency tends to be shot when you start to go for racing performane and I seriously doubt it should even be a design goal. At least not if you want to have a sporting chance...
I know there were several EVs in Pikes Peak that ran AC-motors, but they had a budget for it too. Ie, HUGE! Lots of sponsor money.
I suspect such controllers for a much larger motor that we'd need for the racing car would cost a fair bit and the budget is tight on this one.
"Racing" and "Tight budget" is a bit mutually exclusive. At least if you don't enjoy finishing last...
