Article Tools Display Modes
Default EV Charging Costs and Cost Per Mile
This article will explains how to calculate the costs of charging your Electric Vehicle and the Cost Per Mile. This article will be kept as simple as possible.
Cost of Charging Formula:
Price= Price of electricity from power utility. (usually about $0.09 U.S. per Kilowatt hour (KWh))
Energy = Amount of energy your battery charging system uses (in Kilowatt hours)
Energy x Price Per KWh = Total cost to charge batteries.
Cost Per Mile:
Cost = Total Cost of a full charge of your EV's batteries. (from the formula above)
Range = Total Range of your EV from a full charge, in Miles, Kilometers or any other distance measurement.
Explanation of Formulas:
First you need to understand that Electric Utility companies usually charge per Kilowatt Hour (KWh) for example $0.10 per KWh.
1 KWh is equal to 1000 Watts being used for 1 full hour (thus 1 Kilowatt used for an hour).
If you draw 100 Watts for 10 hours that totals 1 KWh.
If you draw 500 Watts for 2 hours, that totals 1 KWh.
If you draw 1000 Watts for 1 hour, that totals 1 KWh.
Even if you drew 4000 Watts for 15 minutes it's still a total of 1 KWh of electricity.
Cost Calculation Example:
Just some example numbers here to show how the Formulas work, don't take this as what your EV will cost.
If your charger draws 2000 watts(2 Kilowatts) while charging and can finish charging your batteries in 8 hours that's 16,000 watt-hours or 16 KWH of electricity.
Lets say your energy costs $0.10 per KWH, then you just used $1.60 worth of power to charge your EV.
If your utility charges less money per KWH at night, then it could cost less.
Now, to get your dollar cost per mile you take the cost of a full recharge of your EV $1.60 and divide it by the amount of miles you can travel on that charge, lets say 50 miles, you get $0.032 per mile is the cost of driving your EV.
If you want to calculate your equivalent MPG from that electric charge, that's much more complex
These are theoretical numbers, but they represent fairly common values and they are accurate. This is how to get the electrical costs for operating an EV.
Contributors: Persanity, Mastiff, xrotaryguy
Created by Mastiff, 01-27-2008 at 10:20 PM
2 Comments , 10854 Views
Old 08-03-2008, 03:20 AM
xrotaryguy's Avatar
xrotaryguy xrotaryguy is offline
xrotaryguy will become famous soon enoughxrotaryguy will become famous soon enough
Send a message via AIM to xrotaryguy
Default Re: EV Charging Costs and Cost Per Mile
Aah, I think that the formula:
energy x time x cost =
is incorrect. dimensional analysis shows that you'd get KWh^2 from this formula
I made some adjustments.
Old 02-24-2010, 02:01 PM
darel60 darel60 is offline
darel60 is on a distinguished road
Hello.
I own two electric vehicles and its charging costs me very high for my pockets, so please tell me the perfect solution of charging the electric vehicle so that the power can be saved which further helps in reducing my electric bills.
power saving solutions
Article Tools
