Article Tools Display Modes
Smile Current Limiting Formula for LEDs
Thought some might like this formula for limiting current when using LED's in your EV. I'm working on replacing my headlights and all other bulbs in the car to LED's. This formua was provided by a friend from OpTek:
The equation to determine the current limiting resistor is:
(OperatingVoltage - ForwardVoltage) / Current = ResistorValue
Example:
(13.5 - 9.1) / 0.5 = 8.8
13.5 volts was used as the Supply Voltage,
9.1 Volts was used as the Forward Voltage, of the LED module I'm using,
0.5 was used as the LED operating current,
8.8 Ohms was the resulting value of the current limiting resistor.
Power disipation in resistors:
VoltageDropAcrossResistor * CurrentThroughResistor =
PowerDissipatedByResistor
Example:
9.1 (Volts) * 0.5 (Amps) = 4.55 (Watts)
Contributors: TexomaEV
Created by TexomaEV, 08-12-2007 at 08:20 AM
5 Comments , 5583 Views
Old 08-12-2007, 02:08 PM
KiwiEV's Avatar
KiwiEV KiwiEV is offline
KiwiEV is just really niceKiwiEV is just really niceKiwiEV is just really niceKiwiEV is just really niceKiwiEV is just really nice
Default Re: Current Limiting Formula - LED's
I had this link emailed to me this morning from a budding converter in Russia. He's just playing around with LED's at the moment but created these low power indicators.
He used 24 red LEDs (8 candell each) and 100 ohms resistors per 4 LEDs. A regular bulb is disassembled and the leds are connected to the metal part of the open bulb.
The page is in Russian but the pictures are self explanatory. I might just do this myself in the future.
Old 05-27-2008, 03:17 AM
lazzer408's Avatar
lazzer408 lazzer408 is offline
lazzer408 is on a distinguished road
Default Re: Current Limiting Formula for LEDs
If you want to know the voltage across the resistor, wouldn't that be the supply voltage - led forward voltage?
Your example:
__________________________________________________ _______
13.5v-9.1v = 4.4v
4.4v*.5a = 2.2w
Not 4.55w as you've calculated.
Old 07-02-2010, 10:28 PM
dmac257 dmac257 is offline
dmac257 is on a distinguished road
I was looking at the OPTEK website and it shows LED solution for all lights EXCEPT the headlights. Is there a model number for the white light you intend to use for headlight and does it already meet FMVSS for illumination?
Old 07-03-2010, 07:51 AM
TexomaEV's Avatar
TexomaEV TexomaEV is offline
Moderator
TexomaEV is on a distinguished road
I ended up just replacing all the lights in the car with LED versions, and used HID lamps for the headlights for the time being. Holding out for some LED Headlights, once the mainstream auto industry starts to use them. I hope one would be able to eventually obtain replacements when parts houses stock repair parts.
Mike
www.nteaa.org
www.flickr.com/mbarkley
Old 08-04-2010, 09:46 AM
notailpipe's Avatar
notailpipe notailpipe is offline
Location: The best damn country on the planet, subset: Colorado
notailpipe is on a distinguished road
13.5v-9.1v = 4.4v
4.4v*.5a = 2.2w
Lazzer, yes you are right. Perhaps another way to look at is is the power dissipated in a resistor is equal to the current squared times the resistance (play with equations to see equivalence).
P = I^2 * R
So 0.5 * 0.5 * 8.8 = 2.2W as you have correctly observed. This might help others avoid the confusion since the voltages are not needed and the current is the same through both elements since they are in series.
Article Tools
