1 - 4 of 4 Posts
I am looking at upgrading my ADC9" motor to suit a new 1200amp controller 156volts or 192volts.
I am currently running 120volts 800amp controller.
I have been in contact with Kostov and they recon the old KFG-14402 motor‏ will probably not handle the high current.
They recomend 750amps peak and below 4000rpm at 192volts. 180A 4000rpm constant
Anyone have any experience or know of a simular setup?
Not sure if my if it would be a great advantage in swapping my 9" adc motor for this kostov motor to run a 192volt 1200amp controller
dave
G
I think you may want to stick with your ADC but I am not sure if it will live well in that current range for long. Sounds like you are planning on a few hot trips down the track.
Pete :)
1 - 4 of 4 Posts
