Hi there,
My 12 volt accessory battery in my Sera EV is dying mainly due to high draw from vacuum brake pump. The battery is standard 12 volt lead acid car battery about 45ah. It is dying due to high draw and is charged by the alternator which works only when EV is driving. This has lasted well with occasional top ups with 12 volt battery charger when doing a lot of driving in traffic with headlights, stereo etc. Wondering what people recommend these days that is not to costly and easy to get hold of in Auckland as a replacement. The vaccum pump pulls about 65amps when presurising the brake system when running so am thinking thats why after a year the battery has had enough and is starting to drop voltage rapidly even when charged with 12 volt charger every now and then.
Cheers
Theo
Cheers
Theo
