120VDC Lead acid pack not performing well
1444 Views 5 Replies 3 Participants Last post by  tortuga
Greetings I have 120VDC Lead acid pack not performing well. After leaving the pack on the charger for a long time (standby) the battery pack only is only @120V?
I would expect 149VDC no?
I took the truck for a spin today and my volt meter showed 110 - 94V while the motor was running.
The battery states
Constant Voltage charge @20℃
standby Use is 13.6 - 13.8 Initial Current 16.5A
Cyclic Use 14.5-14.9V Initial Current 33A
(See photo)
When charging this 10 pack of 110AH 12V lead acid batteries should the voltage not be 140 ~ 149 VDC?
I am measuring 129VDC to 132DC off the charger @ 7-9 DC Amps.
I cant find much info off the charger it says "InPower" I cant see a model number. Does anyone know anything about these?
Perhaps I will pull out the to see if there is more info.
Thanks in advance.
EDIT after charging for a while I do observe 146V @ 4.5A
EDIT2 I removed the charger and it says CleanPower CHWP-12008
(See photo)
1 - 6 of 6 Posts
Seems normal.
Depending on charger amps output it could easily take over ten hours to fully charge from 50% depleted.
Aged lowered capacity batts can take much longer.
Even a small healthy bat is 5-7 hours.
100% Full would mean tail amps dropping to say under 5A.
Are those supposed to be quality true deep cycling? Not according to vendors, but trusted objective sources.
Yeah okay thanks for the feedback, the UB-121100 batteries are about 2-1/2 years old. I have put about 500 Miles on them in the two years I have had this truck.
I think I found some specs on them here:
https://pdf.wholesalesolar.com/batt...50.417361640.1515196994-1413914165.1515196994
Seems like I can only get about 8-10miles on a charge lately.
Do you think its a bad idea to just leave the charger plugged in all the time when the truck is not in use?
Depends on the charger, if it transitions to Float after Full NP.
They say those batts are only rated for maximum 500 cycles at 50% DoD, way less if you've been going deeper.
Not what I would call true deep cycling.
IOW they're shot, replace with better.
IMO the best lead battery value by far is Duracell (actually Deka/East Penn) FLA deep cycle golf cart batteries, 6V, around $90 per @200+AH from BatteriesPlus or Sam's Club
But keep DoD below 50% if you want longevity.
· Administrator
Replace!
But not with Lead
How much do those cost?
I bet they are more than $180 each - and I got a Volt pack for $1800
Reconfigure it and you will have over twice the available amp hours - nearer to three times
Yeah ouch I am hoping they are not shot. They probably have had ~90 charge cycles.
Its now ~4 hours later and the InPower "CleanPower CHWP-12008" charger now is floating them at 156V draw is ~ 2amps.
I guess its time to look for a 120V Lithium option.
1 - 6 of 6 Posts
