I finally have my
56 ford truck project wired up but I have a controller problem.
The light on the Curtis 1238 controller blinks a yellow light, which I think is good. But after pressing the accelerator the red light blinks and I read a code 47.
The 1238 manual has code 47 as an HPD sequencing fault and lists the following possible causes:
1. KSI, interlock, direction, and throttle inputs applied in incorrect sequence.
2. Faulty wiring, crimps, or switches at KSI, interlock, direction, or throttle throttle inputs.
Also the Set/Clear conditions are:
Set: HPD (High Pedal Disable) or sequencing fault caused by incorrect sequence of KSI, interlock, direction, and throttle inputs.
Clear: Reapply inputs in correct sequence
Is this the way I have something hooked up, or is this a programming problem that will require having the controller reprogrammed?
