NEMA Insulation Classes
Electrical insulation systems rated by standard NEMA classifications to maximize allowable operating temperatures.www.engineeringtoolbox.com
Ha ha. You nailed it. That's how I've been feeling while searching for a motor for my project. They'll state a few specs but don't want to make any guarantees or proclamations.This is a kind of sneaky way of rating motors without actually rating them. You can make as much power as you want to, as long as the temp doesn't go over x. You choose the application and load vs operating time to meet the temp requirements rather than the motor maker going to the effort of supplying data on what to expect for given loadings. It gets frustrating after a while because you are the RnD department in what should be an engineering project. /rant
This is unfortunately very much intentional... The difference between the claimed figures and the reality are sometimes an order of magnitude apart when it comes to steady-state op. This is entirely down to motor makers putting very little effort into the cooling system. I took a motor that was rated like this and spent a year just on the cooling system. The end result was almost 50kW/kg steady state at 45kW output. Didn't change any magnetics, just cooling. Out of the box it was about 1 or 2kW and then only for a few minutes. Tired old ideas go a long way in the electric motor industry. sorry still in rant mode.Ha ha. You nailed it. That's how I've been feeling while searching for a motor for my project. They'll state a few specs but don't want to make any guarantees or proclamations.
So a fan won't help much? It's a $250 tractor. That's why I'm trying to figure out a way to use a $100 motor. I wouldn't want to spend too much on cooling a 50 year old pump motor. I'm pretty sure I can get the ME1004 for just over $600.Notice, he did not list "air" cooling.
Class H is the insulation class, class F is a standard most common, H is a little heavier.... the slot paper and sticks that hold the winding's in the stator.....What does it mean if a motor spec plate says only:
V = 36/48
Class = H
Rise = 140 degrees celsius?
I know what the first two mean but I don't understand the rise. Is that related to the duty rating?
Thanks
The duty rating would be directly related to the insulation.....Class H is the insulation class, class F is a standard most common, H is a little heavier.... the slot paper and sticks that hold the winding's in the stator.....
There are currently four electric motor insulation classes in use: A, B, F, and H (although there are also N, R, and S classes).
The passive system in my post eliminates the pump and fan but is basically the same. A closed loop system would need to be clean and leak free. pressure tested/vacuum testedGet jiggy with it and put some refrigerant through it in a closed loop with a condenser and pump, water cool it, oil cool it...
Common automotive anti freeze, Ammonia water, water alcohol mix, hfc's all could be used. Whether effective or not is another topicYou can substitute just about any other liquid for water with varying effect.
You could make a water jacket around the outside of the motor and thermo syphon it to a radiator above with a fan, you could build it and put a temp probe on the motor windings and let it cool off when it gets to temp
was thinking one could adapt it to cool the motor
Definitely a more expensive solution to the problem than the motor it would be cooling.I just don't see this being applicable in a brushed forklift motor application - at all.
