1 - 20 of 24 Posts
Bonjour à tous,
Je voudrais remplacer mon moteur abm 15kw (voir photos) par un moteur plus puissant au lieu de l'actuel ...
Avez-vous une correspondance pour moi?
Au plaisir de vous lire,
Nicolas.
121911
121912
Good morning all,
I would like to replace my 15kw abm motor (see photos) with a more powerful motor instead of the current one ...
Do you have any correspondence for me?
Looking forward to reading you,
Nicolas.
View attachment 121911 View attachment 121912
[/QUOTE]
A more powerful motor might require a more powerful inverter. What's your inverter rated at?
[/QUOTE]
Hello,
I have a Curtis 1239e controller that must be able to handle a lot more power?
It's in the model number on the side of the controller. If you're using a nominal battery voltage of above 108V then it's the 8521 which has a max nominal (depending on max charge limit) of 144V
I must be on a 6521 version with a 77v battery
in fact, i have a devinci (devinci-cars.com) and my goal is to make it a really "powerful" car in acceleration ...
I have already improved things thanks to the curtis 1313 but I do not master the configuration enough to go further!
maybe the engine is enough?
It's worth examining the controller model number to be sure. Unless you plan to upgrade your batteries, they will likely be a bottleneck for power. You would need to know the discharge specs and cooling provisions for them.
I'm surprised you don't have a label like this:
121929
But there you have it from the 1313. It's a 6521.
You could support something like an AC34/35, AC50/51, or equivalent with that controller.
From the Curtis 1239e manual (ou en français)
Model: 1239E–65xx​
Nominal Voltage (V)​
Power: 60-84​
Logic: 12​
Max Voltage (V)​
Power: 105​
Logic: 20​
Min Voltage (V)​
Power: 33.6​
Logic: 8.4​
Peak Current (Arms) (2min): 550​
S2–60 min Current (Arms): 155​
So yes, the controller can handle more than 15 kW, at least briefly. Even the existing motor ratings are 242 A at 48 V - the current is higher than the S2-60 min limit - so the controller can't handle that for a whole hour. To get the maximum amount of power reliably through this controller, it should be be used with a nominally 84 volt system and a motor suited to that voltage.
Banned
Maybe some idea for you to consider:)
121941
here's more
I see they also use Curtis controller
Discussion Starter · #19 ·
here's more
Hello,
I sent you an email requesting information.
Looking forward,
Nicolas
1 - 20 of 24 Posts
