Plug those numbers into the equation hp = (torque*rpm)/5252 and you get a rather dismal 3.5 ft-lbs of torque for motor that develops 12hp at 18krpm. You would be hard-pressed to use that in a motorcycle conversion because even though their gearboxes can handle much higher rpm, they can't usually handle THAT much rpm!
As for how much power the motor will consume, that's easy: 8.8kW! At the nominal input voltage of 300Vrms, full power of 8.8kW requires 8800/300 = 29.3A of current.
Most EVs seem to work well with motors rated for somewhere between 25 and 50hp continuous output and a peak output of 3-5x that amount; this motor is about half the minimum size most feel is adequate, in other words.
