Hi all, I'm a new member who has a history of restoring old British sports cars and building street rods. I'm 73 and I thought I was through with this restoration business until I saw this 61 Austin Healey Sprite that was for sale. I bought it last summer and started the restoration process. Got it running and driving and then became interested in converting it to electric. I have thoroughly enjoyed learning all that's involved in going electric. I have been involved in electronics since my early Air Force days. Hoping to keep this low budget I found and purchased a motor from a Hitachi/Caterpillar fork lift. It is an 8 inch motor built very heavy (150 lbs?) I have cleaned it up but can't get it to run. Its a series motor with the 4 connections and I have tried tying together an armature and field connector (both ways) When I apply power, a 12 volt car battery, instead of the shaft turning, it is forcibly held still. The motor has no label on it but is either a 36 or 48 V. motor. I feel like 12 V. should make it turn with no load on it. Any suggestions would be appreciated. My intention is to keep the transmission and clutch so it would still feel like a sports car. Unfortunately I have just discovered that the motor is too long to fit with the tranny. A major front crossmember gets in the way. So if I use this motor I would have to connect directly to the drive shaft. I may wind up buying a shorter AC motor. Has anyone used a ME1616 AC motor? The Bugeye only weighs a little over 1400 lbs. I wonder if the ME1616 is large enough to give reasonable performance. The original ICE engine has only 43 HP. Looking forward to hearing from you. I'll try to attach a few pictures. The motor pics are before clean up.
