1 - 20 of 169 Posts
1961 Volvo PV544
Hello All!
I pondered what to do to this car for over 1 year since driving it home. Yes, it was the first project car I had not needed a trailer for! I have travelled as far as Southern Cal. to pickup other projects with a trailer in tow. Never one only 15 miles from home! And so cheap ($2500) for a running vintage car!
Because the starting point was so favorable, it was tempting to simply do a stock restoration. But then I started digging and found the engine and tranny were not original, coming from a newer Volvo. I felt like it opened the door for a restomod. I am soon 72 years old and have always enjoyed a challenge. My last build was a traditional hot rod which included at totally fabricated frame and flat head V8. Parts were either already in my shop or sourced from multiple swap meets and online sales The various parts spanned years 1928 to 1962 in vintage. I also upgraded a 1958 MGA Coupe to a 2000 Miata drive train. I have done a 1956 F100 PU with a 90's era drivetrain from a T-bird SuperCoupe. This past May I drove Rte. 66 in it. 6000 miles round trip. So major technology jumps with previous projects has been accomplished. And I drive the things! But ICE to EV??? Before last year I didn't even know what those acronyms stood for!
I reviewed the topics I was to cover with my first post, and I can see the logic to determine where everyone enters this EV game. So I can fabricate, I can visualize, I can drive. But this EV thing was a bit intimidating. Then I took a ride in a modern EV and got sucked in! With your help, I hope to make this car an almost daily driver. I am planning for 80 - 100 mile range. I also want to approach this incrementally, both for affordability, but also because I like to mock up restomods to present a car look like it could have come from the factory that way. I have become adept at doing this, but it has always been by trial and error with lots of cardboard and wood mock-ups. I have fabricated things multiple times to get it looking right (as well as for structural integrity!).
I hope I can present this EV conversion similar to my other less radical projects. I want the motor with controller to take center stage, so no battery box on top of it, even though there is a lot of room under the bulbous hood. Likewise, I doubled the HP and Torque on that MGA mentioned above, and it suddenly became a fun (not to mention dependable) sports car! While I will only have a marginal HP jump in my chosen EV gear, I am pretty sure the torque value and dependability factors will be satisfying enough!
That all said, I have been working with EVWest to gain a system understanding and with a local Electrical shop that has dabbled in EV development for the last 10 years. EVWest had done a Volvo P1800 several years ago and just this past week we were able to confirm a match to my Volvo bellhousing and flywheel. So I have the adapter/coupler on order with them. I also have a Hyper 9 HV motor system with chill plate and front motor mount on order with the local shop. Saved much on freight by finding a local source for that! I have other components pre-selected from both EVW and locally, but again will use these first major pieces to anchor the mock-up stage. So because the adapter is a long lead item, I will probably be doing more restoration type stuff in the interim, so bear with me.
I attach pix of the car, the voluminous engine bay and similar trunk. I do plan to put at least some battery packs in the rear where the gas tank came from. However only 100-120 lbs or so to help keep within original weight trim. Which I think will be okay, with so much room in front. But again, I want to showcase the motor. Not the battery packs.
Looking forward to hearing comments from this valued knowledge base in the months ahead!
Wheel Tire Car Vehicle Motor vehicle
Hood Motor vehicle Automotive tire Automotive exterior Vehicle
Motor vehicle Vehicle Car Automotive design Gas
John Larsen
Lynden, WA
USA
1961 Volvo PV544
Thanks for the interest! I am currently rebuilding the front end while I wait for EV parts. Sound familiar? As can be seen on the pix, this should help quiet a few knocks and squeaks. Also to this end (quiet) I jacked the rear end up on the car before removing the engine and tested the gear box + rear end through the gears to see if they made noise. Well, I got a nice vibration that turned out to be a universal on the drive line. Once the test was repeated with a new joint, I found that the gear box and rear end were good to go. I then removed the engine. The tranny with bell housing sit on my work bench, ready to join with the motor, once I get the adapter and coupler from EV West.
I am studying various battery brands in the hope of attaining my goal of good weight distribution and esthetics. The 544 was a noteworthy rally car in it's day, and the suspension supports this. The last thing I want to do is make it less road worthy. The esthetics part is just my hot rod quirk.
My first check without motor in place says i can't consider the Tesla packs as they are too long. I have a space in front of the motor which will have to deliver 2/3 my power in a 22"x22"x10" space. Any thoughts?
John
Automotive tire Motor vehicle Tread Rim Bicycle part
Bicycle part Wood Automotive wheel system Nut Metal
A 22"x22"x10" rectangular space has 80 litres of volume (4840 in³ or 2.8 ft³), which could ideally hold about 160 kg of cells (because lithium-ion cells have a density of roughly 2 kg/L), with a capacity of 32 kWh (because lithium-ion cells weigh about 5 kg per kWh of capacity); if that's 2/3 of your battery then your total capacity would be 48 kWh. In the real world you won't be able to pack cells in nearly that well (because they never come in just the right dimensions), and you need space for structure, cooling system, interconnecting wiring, and control devices (contactors, fuses, BMS components), so you might fit a bit better than half of that capacity if you find the right battery modules. I think you need more space...
For an example, two layers of modules in the VDA 355 format (355 mm long, 152 mm wide, and 108 mm tall) with four modules per layer (3 side by side and one turned 90 degrees to them) could barely fit in a 22" x 22" x 10" (or 560 x 560 x 255 mm) box, with an empty corner for wiring devices; the height would be marginal with cooling plates. At 2.2 kWh each, that would be 18 kWh; at 12 kg each, that would be about 100 kg plus structure, wiring, and devices. I used the VDA 355 format as an example because those modules are relatively small (sometimes called "shoebox" size), are an industry standard (which is rare in this industry), and are available from a couple of sources (including salvage from the Jaguar I-Pace); however, it's just an example to illustrate the packaging challenge.
Also, with the motor in front of the original transmission, "in front of the motor" is likely too far forward for all of that mass to allow for good handling.
1961 Volvo PV544
Spent the afternoon using some discarded Jule gift boxes to do a preliminary sizing mock-up. It assumes the use of the CALB 230 Ah cells. Approx. 7"W x 2.125"thick x 8.75" tall.
It will be awhile before I get motor and adapter placed, but I approximated it with the white bucket shown. I had to whittle down the front quantity to fit between the hood hinges but created saddle bag packs to get 4 more. That makes 24/40 in the front. You can see, I will probably be able to catch the front cross member for major support of the 228 lb battery packs plus whatever the frame/box may weight. That put a few more in the rear than I wanted, 16/40 for 152 lb + box. This is about 30 lb more than stock load (gas tank, fuel, exhaust, muffler, etc.) So no worse than a bag of dog food excess. And it fit nicely in the abandoned gas tank hole.
It is possible to squeeze a couple more in at each location, but this is at least a starting point.
John
Motor vehicle Hood Automotive tire Shipping box Automotive design
Gas Metal Automotive exterior Handwriting Rectangle
You want as much of your pack against the firewall, not the front grill, or your car will turn like a cargo ship, not to mention an exaggerated weight and balance cg in the forward direction.
I suggest a small pack on the plane of the motor, then a larger one, that extends to the firewall, above it and the motor.
1961 Volvo PV544
Thanks Remy! The stock engine (approx 350lb) was front supported on the two motor mounts shown just in front of the white bucket. Also can be seen on the attached pic. I will be using a front support on the motor that will support off these locations as well. The front box terminates about where the radiator was located. The only other supporting mount was a single one at the tail end of the tranny.
Would it be viable to build a frame from front mounts to tail mound to replicate what the original distribution might have been?
Hood Motor vehicle Vehicle Automotive fuel system Car
Yup - if you want to keep the original "3 point" mount, a frame/tray is an approach. Keep as much mass as you can tight to the firewall.
Also, the largest percentage of collisions, unplanned or otherwise, are at the front, so not using your batteries as front crush space reduces chances of lighting the battery off in a minor front hit.
· Premium Member
Hi John,
As a 38-year Volvo mechanic, I almost spit out my coffee when I read "...voluminous engine bay and similar trunk."!😂 I guess compared to an MGA, it is!
Looks like it had a B18D with a Webber-Redline 2bbl down-draft carb (86-115 HP) in place of the 70HP B16A and single Zenith side-draft carb. The 88 kW(~118HP) HyPer9 HV should do well and give you much more torque. The original engine had 87 lb-ft / 119.0 Nm @ 5500 rpm.
You might want to get those batteries closer to the center of yaw, to improve handling and get them out of the crumple zones. Maybe place the controls where the front battery box is now and place the batteries off to the sides of the motor?
1961 Volvo PV544
Hey GreyRace! Yes - compared to MGs which is what I also have! But still more than most modern cars afford as well. I mean, you could at least reach spark plugs without burning your hands!
Good calls on all the mechanics although I had determined the engine to be from a B-18B Amazon Automatic. The M40 may be similar vintage, but not original as the speedo cable came off the side and headed straight into the tunnel sidewall.
You need to tell me where the center of "yaw" is. I was a journeyman shipwright in my first career, but yaw was not defined for me!
John
· Premium Member
John
The B18D was just a guess on my part, given the original carbs are gone.
The M40 had a long run from 1961 to 1975, so there's no telling what it's from. As for the speedo cable, it may need an angle-drive in this application.
<edit:> This angle-drive may be too long, there was a shorter version on the early M40-equipped 544s.
With the drive shafts' small diameter and u-joint size, you might need to limit torque in the controller software. (172 lb-ft of torque vs. the original 87 lb-ft)
I see you already found yaw! CG is close enough and will work in this case. You'll want to get the battery(s) mass behind the front cross member, ahead of the rear axle, and as low as possible. This will reduce roll, improve braking, and make turning easier (since you won't be fighting a considerable weight far from the CG). Given the available space and the volume of battery needed, I don't know if you will be able to display the motor as you intended and maintain the handling the 544 is known for. I've put some thought into converting my 1964 Volvo 122 4dr Automatic to electric and decided that the space in the trunk above the axle would do for some battery storage and have the added benefit of placing some weight over the rear tires. You could also delete the transmission, go direct drive and tuck the HyPer9 HV partway in the drive tunnel, leaving room for the motor frame/battery tray you mentioned.
1961 Volvo PV544
Discussion Starter · #20 ·
Lars (oudevolvo),
I went to your website where a Volvo 120 series is pictured: Enabling your electric car conversion project - EVcreate
It appears to have a front battery box tucked up to the firewall on the passenger side. Is this the combi project? I thought the combi/station wagon used primarily a rear battery box. Can you provide details and why only one on the passenger side?
Thanks,
John
1 - 20 of 169 Posts
