Do the battery box right and you can put a set of fake flathead plates on the angled bits, or fake rocker covers.
The V16 lives...
The V16 lives...
The rear end will see the same speed regardless of the motor and/or gearbox ahead of it, because the axle input speed is directly proportional to the road speed, tire radius, and axle gearing.... regardless of the transmission.One reason for going with the original transmission was that an adapter and coupler had already been designed, so initial cost was favorable. I am also not sure the existing rear end would be able to handle direct drive in terms of rpm's.
Not really. The clutch disk can provide rotational "cushioning" (they usually have a spring hub), but does not forgive alignment error.The clutch might also provide a measure of flexibility in terms of "cushion" on alignment.
I don't know what is typically supplied with a kit, but if the transmission shaft is piloted in the flywheel or crankshaft (which it typically is in conventional longitudinal transmissions), you need that bearing or bushing.Also, no pilot bushing was provided for the transmission input shaft - Is this typically omitted? It appears I could fit a bushing/bearing in the end of the coupler. Once I get it on, that is...
With clutch slipping, the engine can deliver that torque (through the clutch) at any road speed up to that corresponding to to the torque peak engine speed in the current gear.In my view the Hyper 9 is not powerful enough to do a direct drive. The highest voltage version outputs 220 Nm.
The original B18 in first rear would put 3,1 x 150 Nm (ok, at higher rpms) = 450 Nm onto the driveshaft.
Availability certainly does vary greatly depending on the final drive (axle)! Most don't have a short enough gear set (high enough reduction ratio of the ring and pinion) to make sense as the only reduction for most electric motors.Unfortunately for the Dana or Spicer axle there is no replacement rear diff gear to compensate that.
Interesting page - thanks for sharing that. It doesn't mention any final drive or tire information, which is a bit strange considering that they are critical to comparing motor and transmission combinations, when one of them has its own final drive.In my rebuild I’m 100% sure I will eliminate the gearbox. That was a noisy and one pedal drive spoiling thing.
More info here Rear wheel drive EV conversion motor options - Voltvo
The M40 and M400 gearboxes are classic longitudinal designs, in which the input shaft clearly requires support at the front. That's what the pilot bearing (or bushing, but Volvo uses a ball bearing) are for, although one might get away with supporting and locating the splined shaft adequately.I used a M400 gearbox without pilot bearing.
