So I covered it. There goes my electric motor showcase...
what you see is a mock-up of the proposed CALB LiFePO4 230Ah battery pack. 28 pc in front as shown, and 12 pc in trunk. This will round out the weight distribution nicely and give me the voltage/range desired. This seemed to be the best combo to get what I needed in the space available.
As you can see, I have pretty much filled the engine bay except on the fringes. I am thinking as a minimum, I want to locate the controller (seen in second pic) with chill plate where the old 12V battery sat (mid firewall cavity) as it is the most structural place to go - unless it is better to have the 12V battery up front.
I will also have the small water pump and small radiator for the chill plate behind the grill area - lots of room there. Anything else you might suggest behind the grill that is low crash damage risk?
In the rear, I am thinking DC-DC charger, Main charger, etc. I am planning a bulkhead mounting panel in the rear trunk area.
Ideas please!!
Ideas please!!
