Hi, I am a Mechanical Engineer by trade and somewhat weak in my knowledge of electrical components. I would like to understand the options and capabilities of adding electric motor/motors to a car I started many years ago. the car is a 1962 corvette, however I had a tube chassis built and the suspension and drivetrain from a 1999 corvette was added. I would like to understand some general options to see what is the best path to explore. My understanding from doing some reading is that there are a lot of ways to accomplish the same things, each with good and bad. so let me first list what I think are major paths with the hopes that some of the more experienced builders can get me started down the right path of investigation.
Obviously with a corvette i would like to get good performance, similar to the 1999 in stock trim. I dont need or want a race car, but would like it to have respectable power.
In case someone is not aware, the 1999 corvette has an independent rear with a transaxle, the transmission is attached to the rear differential and the motor is attached through a long tube from the front. My car has the manual 6 speed, and an automatic is also available. I am looking for some pictures of my specific frame but I have not found them, sadly the car is buried right now so i wont be able to show much of its construction until I am ready to start. For reference the frame was built by SRIII motorsports about 15 years ago.
1. I see a lot a Tesla big and small rear motor conversions, this seems economical but I am not sure how well that will fit on my rear subframe without a lot of reconstruction.
2. I see that there are many large DC and AC motors like a warp9, warp11, warp13. I could either attach this directly to the front of the differential or to the front of the 6sp transmission, however the best fit by far would be to eliminate the transmission.
3. reverse, is it costly to use the electronics to reverse, or does having a transmission simplify/cost reduce enough to justify the transmission?
4. can you get Tesla performance from the warp type motors?
sorry, I know these are very general, but this is my basic understanding so far. Thanx for your time and patience.
