Hello All
I've purchased a tragedy of a 1964 Ford Econoline van and I'm going to EV it.
The plan is to pull ALL of the running gear out of it and install an all wheel drive Subaru chassis underneath ( I need the AWD ).
I've sourced a front sub assembly with auto trans, and a rear sub assembly.
The Ford has two beefy rails that run front to back that these assemblies will be affixed to. The rails are the only structural parts of the van that are solid. Everything else will be upgraded/repaired/replaced.
I need to source a motor to link to the tranny. I'm thinking a Netgain 9", I have room for large battery packs under the floor. There is an power accessory assembly bracket available.
I am not expecting high performance.
Pictures to follow.
Pictures to follow.
