Hello all!
I am just about to install my leaf motor in my van.
I have a few 1967 Ford Econoline HD vans to work with. and almost 2 complete Leaf systems.
Leaf parts:
2014 motor
2014 VFDrive
2014 6.6kw charger
2014 24kw battery (66,000km)
The charger, drive, and battery all match and were salvaged from a single car.
I also have a second motor, inverter, transaxle, driveshafts etc just in case.... (2016 model)
I have a fiat 20spline clutch fitted onto the motor shaft
I am purchasing 7.4 - 1 ratio gear set for the Ford 9" differential.
I will run the motor directly to the driveshaft
I would prefer to use the Leaf pack as a whole unit still in original case. It fits on my van floor easy for now.
I have the Thunderstruck VCU kit with pedal and contactors.
I have MOST of the Leaf wiring harness that will be needed.
And now my big question::::::::::::::::::
I hope to use the battery as it is. I see it has all the bms, contactors, heaters etc in it... Is it possible to use this battery in its stock form with the Thunderstruck system? I mean use the Leaf battery, Leaf contactors and Leaf charger all in its orriginal metal shell with the Thunderstrukc VCD?
Although I have read a TON of stuff over the last decade and built a dozen or so RC ebikes etc,,,, I am a newbie to the Leaf stuff. But very eager to learn!
Looking forward to working with you guys through my project. As soon as i figure out these last wiring bits ill be rollin!!!!!!
shnitzel
Leaf parts:
2014 motor
2014 VFDrive
2014 6.6kw charger
shnitzel
