Well done Jaesin! It looks and sounds just right. I'm glad you went to the trouble of milling a proper keyway in the shaft.
It's a shame that space is so tight inside the transmission end plate, but then it wouldn't be a mini without all the space constraints to deal with...
I'd just finished rebuilding my subframe and motors, snugged all the bolts up, installed the reversing contactors, made and fitted the main power cables, then did a bench test and realised I'd forgotten to fit a couple of spacers on the stub drive shafts, so the driven sprockets are free to slide up and down the shafts... Doh!
