1 - 8 of 8 Posts
I've been contemplating converting my 1981 Ford Fairmont wagon to an EV, off and on for about a year now. It took me 9 years to find one than wasn't rusted out or wrecked bad. I had originally planned to make it a 5.0 V8 5 speed car; a sleeper hotrod. I have it on jack stands in the garage right now.
I would like for this car to be my daily driver for work. It is 19.9 miles to work, so a 40 to 50 mile range would be needed. About half of the route is shallow hills on local roads with the speed limit 40 or 45 mph. About 6 miles are on the interstate at 70 mph. The other part is 25 or 35 mph in town.
I figure a DC motor conversion with a 144 VDC supply would provide a decent amount of power and distance at a cheaper cost than an AC conversion and be simpler too.
I plan on it being a 5 speed manual transmission car. I have a 2.26:1 open geared rear and a 3.73:1 limited slip geared rear. Do I need the lower geared rear, or is it a waste of energy, since the electric motors have their max torque at start? Is a limited slip a waste in an electric car? It will have manual disc brakes on all 4 corners, with manual rack & pinion steering.
I have built a few hotrods to include their engines, and tranmissions. I have plenty of tools and a garage to work in. I understand electronic theory and have built a few projects to include audio amplifiers, bass contour networks, passive and active crossovers, power supplies, computers, voltage regulators, converters, etc.
I would appreciate input, advice and recommendations. I have never done an ICE to EV conversion, but am excited about the possibilities. I have also considered converting my 1970 Falcon wagon too, but figure it would be too heavy to be an efficient candidate. Thank you.
Darrell R. Miller
Most people don't know the 1979 thru 1993 Mustang was built on the Fox chassis. The Fox chassis is a 1978 Ford Fairmont. All of the readily available HiPo Mustang parts bolt on. This is the reason I have subframe connectors, tubular upper and lower rear control arms, disc brake 3.73 8.8 rear, tubular front K-member, tubular lower control arms, coil over strut conversion, manual disc brakes, tilt column, manual rack & pinion steering, bump steering conversion, driveshaft loop, etc. The Fairmonts are lighter than their Mustang counterparts, by 250 to 650 pounds, according to options. It is a lightweight & strong chassis with a wide range of parts availability. I know it's a square box, but it also has plenty of room for batteries and components too.
Thank you.
Darrell R. Miller
Actually, 1978-83 EV Ford Fairmont Wagons were factory converted when new. They still come up for sale. See:
http://www.evalbum.com/2298
Russ Kaufmann
RUSSCO
Yes Russ you are right- we stripped a few of parts years ago. The main problem with them was they had a 120 volt system with a GE 11" 120 volt motor at @ 1800 rpm, so the top speed through the automatic transmission was about 45 MPH.
The pictures to the link shows the original battery boxes, rubber coated steel...
Mike
www.EV-propulsion.com
Discussion Starter · #7 ·
So, does anyone have any suggestions about rear gear ratio? Do I really need the 3.73 gears, or would 2.26 gears be more in line since the electric motors have max torque at start? Is a limited slip differential a waste in an electric car? I plan on a T-5 manual transmission. Thank you.
Darrell
I would leave the gears as is- you can always use a higher gear if you feel the need to raise the final/total ratio. A lot of ev'ers start in second gear. Always good to have a low gear ratio available for when you want to tow a boat with that wagon! As far as limited slip, if you are in a low traction situation it might come in handy just as it would in an ICE.
mike
1 - 8 of 8 Posts
