I'm new and am planning to convert my 1986 Honda CRX into an EV. I have a 2015 Fiat 500e for parts but from what I know so far, the Fiat is sensitive and difficult to use for parts. I believe it uses the Bosch 180/120 based on my Google fu. I've sourced the wiring diagram for the vehicle and confirmed it is indeed a 3 phase AC motor, one for each phase, 2 wires to sense temperature, and another 6 for the resolve (excitor, sin, cos). The biggest challenge is that Fiat uses canbus and the controller, inverter, battery, and more likely will not operate without all the parts. The car almost disabled itself when I changed the radio to android auto makes a good example. I am studying how canbus works in order to see if I can either ignore errors or maybe even hack the system to work.
As back up if I have to build from scratch, I have a separate thread pending approval where I'm asking about the compatibility of the Bosch SMG 180/120 with the Scott drive 250 AC controller.
Also I'm reading I might need an inverter? And what else? I'm still digging through the site trying to figure out what are all the parts needed to run an EV with an AC motor, which seems to be more complex and less popular than running DC. So guides or hints are welcome as I learn the anatomy of an EV.
Edit (2021-12-06):
Current project is now to convert the 1986 Honda CRX using a 2013 Nissan Leaf as a donor car in combination with the Resolve-EV Controller.
Edit (2021-12-23):
Project has begun; Battery Dropped; still need a machine shop to make parts.
Edit (2022-07-14):
Car has been running since June 2022. Car has been inspected by the California Referee Station and certified as an EV. DMV has issued registration though they're still trying to figure out internally how to actually label my car as an EV.
My latest work on this build has been to upgrade the battery from 24kwh to 40kwh. Batteries are installed but I still am working out the BMS issues as a bruteforce upgrade doesn't accurately recognize the battery capacity differences.
The to-do list is on-going and always evolving so although the car is running, I'm likely to be doing some new upgrade or change all the time.
Edit (2022-10-23):
Started building a battery box which is the "final battery" box. Still in the planning state but measure many times and cut once.
Edit (2022-12-27):
Battery Box is built and now revising the bus bars and BMS connections to the latest design.
Edit 2023-01-10
Got it running on 2022-12-30. And got it back on the ground and took it on a road test 2022-12-31
Been cleaning up and doing misc upgrades since.
