So I checked the wiring diagram and the J1772 Control and Proximity are wired directly the plug that goes to the PDM. It can be disconnected or probed when it's in the Leaf.
I also remembered that I ran these two wires inside the car.
So I looked in a tugged in the wire a bit trying to see if I could reach the plug. It's stuck behind the plastic car trim that covers the fuel spout area.
I decided I'd try to check continuity of both wires from plug to the PDM plug before testing resistance and voltages. But before that, just plug it in to the charger just in case?
And it started charging. So it's probably related to me tugging on the wire/connector for the Control and Proximity wires.
In the meantime I'll let it charge but I definitely will check the wires after I get to 80%.
Separately I came up with a "debugging process" for j1772.
Hopefully that helps someone else (fyi @Electric Land Cruiser )
- Check if car detects charger plug is connected. If so then proximity is good.
- Listen if charger relays activate. If they don't then there's something wrong with Control pilot.
- Check control pilot wire and continuity from end to end
- If continuity is good, check voltage, resistance. This should provide the status.
