1986 Jeep Comanche $1,800.00
ICE removed and 10" Mars motor 85 peak HP (me1002 Mars motor), coupler, adapter installed,4 speed clutch less, manual steering this is a running ev truck. Will no battery's go with the truck. The ev conversion is mostly complete, the restoration of the inside cab still needs to be done. Truck can be test driven.
120v kelly 1000 amp controller (KDH 12100D) Albright SW-200 (LEV 200 A 4ANF), 400 amp breaker with remote trip,2/0 welding cable, battery box and charger box ( set up for 10 chargers)
The Jeep Comanche has lighter curb weight the the Chevy s 10, and a larger payload.
Mars me 1002 http://www.cloudelectric.com/product_p/mo-me1002.htm
The newest motor for Electric Vehicle Conversions. More Powerful and Efficient then the ADC and Netgain 9" Motors.
The ME1002 is a Series Wound DC motor perfect for lite trucks and small car EV conversions. It is 10 inches in diameter, weighing 203 pounds. Continuous current of 200 amps, and 550 amps for 2 minutes. Voltages from 48 to 144 VDC. Efficiencies of up to 92%. Perfect for use with the Curtis 1231 or Kelly Motor Controllers. The power is 26 KW (35 HP)continuous, and 63 KW (85 HP) peak. More powerful than the NetGain Warp 9 and ADC FB1-4001 motors.
48-144V VDC, 200 amps Continuous, 550 amps Peak 2 Minutes
25 hp Cont, 70.7 hp Peak @ 96 Volts
32 hp Cont, 88.4 hp Peak @ 120 Volts
38.6 hp Cont, 106 hp Peak @ 144 Volts
