I got a new donor car yesterday and I wanted to post to mark the beginning of this conversion. It is a 1991 Toyota MR2. I have a 2004 electric transaxle and inverter out of a Toyota Prius that I am going to put in it. I have been experimenting with the control of the electric transaxle for some time now with partial success. I was trying to fit it into a 1966 VW squareback but I got overwhelmed with the amount of rust and restoration that was needed on the donor body. I should have listened to the advice of others that cautioned about what makes a good donor car. I have to learn the hard way apparently. I may still be in the hard lesson mode since there are not many people trying to use the Prius motors but time will tell.
This car needs nothing but a paint job and the interior is perfect so I can focus solely on the electro mechanical aspects of the project. The mid engine design looks like it will work well for my transaxle and conversion plans.
I will post some pictures of the engine removal once that happens but the wife has declared that there will be no dis-assembly until the VW shell is gone.
The first phase of my plan is to get the car to a grocery getter stage with the small 48 cell 40Ah pack that I already have. In this stage I am not going to bypass the DC boost within the inverter and I am only going to engage the main traction motor (MG2). In this configuration I will be limited by the boost circuit of a 100 battery amps or so.
Once this is functioning I will attempt to increase the power. This is where the fun will start. In addition to adding more cells I have a couple of ideas how to get a considerable amount of power with the Prius setup. I can either start to include the other motor/generator (MG1) and bypass the boost circuit or I can use the MG1 inverter stage IGBTs and some additional inductors to increase the DC boost circuit capacity driving MG2.
Thanks
Jeff
Thanks
Jeff
