Hi Yabert - no real deadlines yet. Right now its a project wedged into the usual chaos of life with kids in sportsGlad to see you here.
The 0.29 Cd is a really good thing... I know what I'm talking about considering my 0.38 Cd Smart fortwo (aka little Brick!)...
What kind of schedule do you expect? Date to first road test? Date of purchase of cells?
It is a fun little carI had a 95 Tsi, bought new and drove the crap out of it.... fun when you keep the turbo spooled up, but pretty heavy around town. I always had problems with windshield fogging like crazy in the winter.
Yep, already have a PM motor from another project that should do the trick. I'm thinking about a PWM circuit to modulate pressure and maximize efficiency of the stock gear pump. I'm also keeping the AC - currently investigating electric options, but am also planning to run it off the secondary shaft.you're going to have to retain power steering probably.... so plan on an electric pump for that.
My motivation in going HV was to keep max current lower and thus reduce resistive losses and potential thermal issues. Perhaps phasing will be a bad idea, don't know? The spare tire well is cavernous and there is alot of room under the hood. I might even do a small pack in the existing fuel tank location (under the rear seat) - not sure about dimensions though, I have to remove the tank yet.Also, a word of caution in going over 160v nominal is that components get a lot harder to find and much more expensive. To keep weight and cost down, I'd stick w/ 156v nominal x 100ah 'new' CALBs
What's inside that offending case? Any chance to just modify that case, perhaps just cut it along the green line and seal it against your motor?Latest Problem:
The K11 interferes with my transfer case (red line). So I'm going to have to come up with an offset drive setup. I really don't want to remove the AWD (thats why I picked this car, after all !!!). So time to get designing and see how a silent chain drive might work....
Its a common setup in almost all transfer cases in SUVs and 4x4 trucks. Correctly designed they can run quietly at 99% efficiency and 40m/s linear speed.
I'll have a very tight center to center on the shafts and the chain case will be extremely compact (2-3"). Anything wider and the motor will interfere with my front frame rails.
Below is only an example of an NP242 from a Jeep. I'll try a similar idea, just much more compact. 6061-T6 aluminum case/adapter plate combination. Time to get cracking on a design....
Hi Ektus,What's inside that offending case? Any chance to just modify that case, perhaps just cut it along the green line and seal it against your motor?
It's hard to judge from the picture, but if the gears don't interfere and the cap has no structural duty it could be possible.
Regards
Ektus.
Yep, still keeping the clutch. The stock synchros are not at all forgiving. In the end if I find I can easily shift clutchless, I might remove it. But the first go around will keep the clutch.I know you were going to keep the clutch initially are you still going to try and keep it with the chain drive?
Hi piotrsko, the adapter itself could be trimmed to clear that area. Problem is that the K11 motor is the diameter of the green line. The transfer case is about 6" thick and interferes with the motor. I'd require an adapter at least 6" thick to move the motor away from the transmission and clear the transfer case. I cannot do that because the motor would then hit the front frame rail. So the only option is to offset it.Ok dumb question: what kind of adapter are you planning? Pretty certain my CAN-EV adapter will clear the red / green line area if I whacked part of it off. Probably not even need to whack stuff off the adapter because it sits back about 2 inches . clutched or not, wouldn't matter, but the Ranger shifts so much faster and easier with the clutch
Hi tylerwatts, interesting your Rav4 is so similar. What year is it?Old.DSMer
I have the exact same problem on my 4wd transaxle! Been limiting myself to motor diameters ~220mm/8.5" which really hits the power capability. Alternative is a longer motor, btu I am talking AC motors.
That Kostov is a great choice of motor in my opinion, have you already purchased it? What power/performance are you looking for?
What is the maximum diameter your transfer box will allow? it looks quite similar to mine. Mine is in a Toyota Rav4 by the way.
