1 - 2 of 2 Posts
Testing the waters I have two wheego lifes with bms issues and the motor, gearbox, controller, electric brake steering and a/c from a third life . I have two cells to replace two bad cells in one. The other has bad cells as well. I also have the bms from an epic torq which could be used in place of one of the failed wheego bms. I have already purchased ALL the software to reprogram ANYthing on the vehicle but no cables as of yet. Between the two there are 5x good 260ah lifepo4 cells, each car holds around 11x.xx volts right now. Could reprogram car and make it drive at those levels. Make an offer on anything you might be interested in local pickup only in Georgia.
1 - 2 of 2 Posts
