Pictures for above post
I have 6 used 12v lead acid batteries installed and holding voltage at 74v.
I will give it a try. Wish I knew what the LVC was.First, You might want to charge those batteris, they practically discharged at 12.3V each.
You should see 76.8-77.4V when they are charged.
Seems like its only low battery and the controller shuts down, then when the voltage bouncing back it's on again...
Based on the above it Sounds like no current is flowingI don’t have a load tester.
I have a good meter and a genius 7200 charger.
I will test the drop.
I did have it on one side of the contractor last night and the voltage didn’t change when hitting the pedal. Should I test voltage drop at the battery ?
I'm going to start with the grounds under the dash and connect them to the - of the 12v accessory battery (this is working, i have headlights, signals, etc.).Based on the above it Sounds like no current is flowing
