1 - 1 of 1 Posts
2010 ZERO S, electric motorcycle. $3200 OBO
New battery, 1700 miles ago (better technology than the original battery,will last a lot more).
4100 original miles.
Specifications:
Motor:
Type Brushed permanent magnet electric
Top speed 67 mph (105 km/h)
Power System:
Capacity 4 kWh (58volts @ 70Ah)
Range Up to 50 miles (80 km)* - See real world range tests
Recharge time Less than 4 hours
Charger type On-board
Input Standard 110V or 220V
Drive Train:
Transmission Clutchless one speed
Drive system 16T / 53T, 420 Chain
Chassis / Suspension / Brakes:
Front suspension travel 8 inches (203.2 mm)
Rear suspension travel 8 inches (203.2 mm)
Front brakes 2 Piston hydraulic, stainless rotor, hand actuated
Rear brakes 1 Piston hydraulic, stainless rotor, foot actuated
Front tire 110/70-16
Rear tire 140/70-16
Dimensions:
Wheel base 56.8 inches (144.3 cm)
Seat height (standard) 34 inches (86.4 cm)
Low seat height (option) 32 inches (81.3 cm)
Rake 22 degrees
Trail 3.26 inches (82.8 mm)
Steering angle + 35 Degrees, -35 Degrees
Weight:
Frame 18 pounds (8.16 kg)
Power pack 95 pounds (43.1 kg)
Curb weight 273 pounds (123.8 kg)
GVWR 575 pounds (260.8 kg)
Carrying capacity 302 pounds (136.0 kg)
1 - 1 of 1 Posts
