Sure - it's a low pressure system. You can probably jam a hose in and wrap it with duct tape, and that would work, too. I wouldn't suggest that...
Sure - it's a low pressure system. You can probably jam a hose in and wrap it with duct tape, and that would work, too. I wouldn't suggest that...Whether or not they are supposed to work, I'm using nylon US garden hose thread (3⁄4-11.5NH ) to hose barb fittings on those threads and they have performed without leaking for more than a year now.
I have to apologize. I was reviewing my setup and realized that I forgot a key part: I did use the o-ring from the original fittings. The nylon thread/barb fitting (Lowe's stock) had a nice shoulder on it that captures the o-ring well enough with the removal of a thread or two (dremel tool). The thermostat/heater housing that the fitting threads into has a recess for the o-ring.Sure - it's a low pressure system. You can probably jam a hose in and wrap it with duct tape, and that would work, too. I wouldn't suggest that...![]()
That's interesting... so it works basically as intended, but limited in engagement force and fit by the thread taper mismatch. Probably just fine for the low pressure.I have to apologize. I was reviewing my setup and realized that I forgot a key part: I did use the o-ring from the original fittings. The nylon thread/barb fitting (Lowe's stock) had a nice shoulder on it that captures the o-ring well enough with the removal of a thread or two (dremel tool). The thermostat/heater housing that the fitting threads into has a recess for the o-ring.
Hmm? Neither of the threads is tapered.That's interesting... so it works basically as intended, but limited in engagement force and fit by the thread taper mismatch. Probably just fine for the low pressure.![]()
Sorry! I had typical plumbing threads in mind and was thinking of NPT, even though this was clearly about the "garden hose" thread. Of course that's not tapered (it seals with a gasket against the end of the male fitting, like a crude version of an ORF fitting) and there's no issue here.Hmm? Neither of the threads is tapered.
To my knowledge nobody knows how to get the BECM to balance the pack. But we do know how to command the BICMs to do so:Hi All. I'm a bit late to the party, but I managed to get a 2012 volt pack for a screaming deal, which I hope to be able to use as a test pack for my current project, and then eventually in another conversion that doesn't need much range.
My goal is to use this as-is initially, although I am not 100% sure it's possible - just keep the entire battery in it's enclosure, hook up ground, 12v, and CAN wires, contactor enable wires, and high voltage cables, cooling lines if in the vehicle, and use it. Is this possible, including getting the bms to self balance? It seems so according to the code on Damien/Tom's AmperaBattery repo in GitHub
It's been sitting for a while and the voltage is currently 348v which I think maybe ok, but would like to charge it up in case it sits for any longer (it might at the rate I am going).
So, using the external connectors I hooked up 12v to X2 pins 1,4,9 and ground to pins 5,10. I hooked up X1 pin 1 to CAN high, and pin 3 to CAN low. SavvyCAN reads messages just fine, but I only see one message interpreted showing battery voltage for cells 1-3 (0x460) using the DBC file I got from the AmperaBattery project, whereas it (and Damien's video) shows several others that I should be getting.
I then tried connecting directly to the internal CAN network @125kbps using the slave module wiring harness connector instead of via the BECM per the wiring shown in the repo and video (CAN high, CAN low, Gnd, 5V along bottom row right), but i don't even get any CAN messages that way.
It doesn't matter if I have the service disconnect in or not.
Two odd things worth mentioning.
The first is I have another front piece which has the BECM and connections, but nothing ese connected to it, and I get the same set of messages, which is suspicious! Maybe these are cached in the BECM?
The second is the voltage on cell 3 fluctuates from 0 to 3.5ish volts - i am hoping this is not accurate and just my shoddy test wiring or something. For the "head" only it fluctuates but in the 0 - milivolt range.
Any thoughts? Is it just that mine is sending different message ids and I need to get/use another dbc file (or figure the messages). I don't want to try enable the contactors and charge it until I understand it's condition better.
tia,
charles
I can only offer minor comments (subject to remembering correctly; it's been awhile):First, thanks for taking the time to reply, and confirming the balancing can be achieved with Tom's code. I should have chosen my words better - having to have some code to send CAN commands to achieve this is perfectly fine if I can get it to work! And thanks for linking to the other thread. Despite searching and reading for hours I clearly haven't found all the info out there on this
Any ideas on what's going on here? Since the middle connector works on the next module, I am assuming the harness is ok, and its the BICM.
thanks,
charles
Aah I was wondering how they could be identical but give different messages - makes sense.To make sure the #2 BICM is bad, you can swap it with #3 and see if the symptoms follow. BICMs 2 and 3 are completely identical. They take their identity from which pins are shorted in the connector (there's a little loop of wire).
See my PMAah I was wondering how they could be identical but give different messages - makes sense.
I just physically swapped them (although its essentially the same test I did before, and I get the 0x465, 0x475, 0x7e5 messages.
I'll try get a replacement. Anyone have one they don't need? It's the one numbered 22911432
thanks again,
charles
If this happened before you received the BICM I sent, you can try it with just that known-good BICM. The BICMs will respond independently.The reason I am asking is because I was having trouble getting it to work before, so don't want to rule out doing something else wrong as well, with the BICMs actually being ok. I don't think it's quite as simple as it worked before, and now it doesn't. Previously it didn't work, then started to partially work, without me being fully sure what changed in between. I tried to describe this in my 2nd post above.
I also don't know if this affects just the first BICM or all of them, or if they could even be repaired. There are no signs of damage on the board, but I am not an EE.
I will likely end up buying at least another BICM #1 to see if perhaps just one is damaged, if anyone has one, but I feel like I should try prove I damaged these first. no?
thanks,
charles
