1 - 2 of 2 Posts
Would like to add 5 KWH to my 17kwh battery, or more.
Any ideas, I would even be happy if the smaller pack could just connect to the main pack to bump up the voltage to extend range, portable DC charger.
Fiat 500E has same motor I was told, I believe some had 30kwh packs.
Any ideas LMK.
There hasn’t been much interest in modding the components from low volume cars
So your really on your own to disassemble the Smarts control systems and modules
Even on cars that are well supported (cough leaf/volt) adding battery to the OEM car has only been done by a couple folks and poorly documented.
The leaf battery module swap technique is the only “almost common” mod done to OEM cars and even then there are no 3rd parties that offer expanded battery capacity.
And really without aftermarket you are going to have a lot of work ahead of you.
Good Luck
Ryan
1 - 2 of 2 Posts
