1 - 2 of 2 Posts
I purchased a Smart Fortwo with a bad hv battery. Anyone have one or know someone who has one?
That's the Li-Tec on right?
If you find one at a junkyard...be quick...
They all die (the batteries), BMS is sucking cells empty. When parked with empty battery it can go fast.
I haven't found anyone yet who can reset the bms, usually the cells are fine, but even if you charge them manually (opening the battery case), the bms still has a fault set.
1 - 2 of 2 Posts
