My RebirthAuto kit came with a "MARINCO #150CCI" inlet. It is a close fit to the hole where the gas inlet was, but not quite. I haven't installed it yet, but it's rated for 15A and my charger draws only 12A @ 120VAC.
I thought it'd be cool to use a power cable with a spring loaded coil. Kinda like you'd see on a vacuum. That way you wouldn't need to whip out an extension cable when you want to charge somewhere other than home.
Edit: this one is meant to have stripped wires terminated into the back-side, but I agree a female port in back would be cool. I hope you post if you find one like that.
