1 - 17 of 17 Posts
Hello everybody,
I and some guys started a project which would be an inverted triangle buggy.
This is probably first project from China here(forgive me if my English is not well).
We are in a DIY group and planed to start from a simple way: one wheel drive buggy. After adding and testing functions like auto-parking, remote control and speed test etc, we may build four wheel drive full function car.This could take long time, we will do it step by step.
At this moment, a 1.5KW/72V in-wheel motor and a controller are tested and working well. Will keep updated if it has any progress. :)
Neat. Like a beefy golf cart.
The CG might be a little high and far back for stability with the passenger seating as it is though.
Thanks for your information.
CG is our concern due to seats arrangement. Will see how to adjust after we have full 3D diagram. Beside passengers, battery is the heaviest part which will be put in the front.
Any design rule or simulation tool for stability? We have experience on electronics, SW and MD, but not good at this.
Discussion Starter · #9 ·
With a 1.5KW motor, 2 people, 3 wheels and a pile of batteries, you might be able to keep up with bicycles!
:) Yes, 1.5KW is definitely not suitable for this. Our plan is to build a test platform first and then add/change/validate components as we are building everything from zero.
The in-wheel motor could be 8KW by same size and we may apply it to all wheels. Now just save money on design of other parts.
Wheel motors are one of those technological blind alleys that look like a good idea but in practice are a disaster
The basic issues are
(1) Motor torque is proportional to weight - you need a lot of torque for a wheel motor
(2) Unsprung weight is a very bad idea
For your rear wheel a motor and chain/belt drive will be a LOT lighter, cheaper and more efficient
If you want to drive the front wheels a reduction gear and driveshafts will also be lighter cheaper and more efficient
Thank you. Will keep it in mind and try to make a modular design.
Look up a BMW Isetta.
Perfect for your project. They are balanced nicely too!
They would be easy to vacuum mould from thermo plastic. The top and rear body panel from one sheet, each side separately and the front panel, (The door). Which can be an outer bonded to an inner panel, really light and stiff.
You would make replacing crash damages easy and cheap. No painting as the plastic is colored to begin with. The interior panels can be moulded too, except for the seats, which are padded and covered.
You just need to go to the Palm Springs airport where a dozen or so are parked and 3D scan one.......
QC
QC
a really good reference. Thanks.
found more projects like this:
http://reversetrike.proboards.com/thread/336/spartan-trike-project
1 - 17 of 17 Posts
