1 - 11 of 11 Posts
Hi All,
I hope you good people can help me with my quandary,
I recently bought a 2013 Ford Connect Transit Azure Dynamics,
the vehicle is in good shape but charging is slow,
it came with 3KWh wall type 1 (SAE J1772) charger (230V/13A),
it can take up to 12 hrs!
I came across conversion cable from type 1 to type 2 ie it allow me to hook the vehicle to public chargers of 7KWh,
Unfortunately - as Azure Dynamics long gone out of business I am
not finding much information about the vehicle so my question is ...
WILL MY PLAN WORK?
thanks.
The equipment on the wall is just a fancy cord and connector, which communicates with the vehicle to ensure that it can safely supply power. The power it supplies is the same 230 V AC power that comes into it. The charger in the vehicle must convert that 230 V AC to DC at the battery voltage... and the charger in the vehicle is probably only capable of 3 kW, using single-phase 230 V power. To use more current from the charging station, or to use three-phase power, an adapter cable isn't enough: you need a charger in the vehicle which can use that power.
The unit for power is the Watt. The Watt is defined as 1 joule per second. KiloWatt -> kW.
kWh stands for kilowatt-hour, an amount of energy equivalent to that many kw for 1 hour, so 1kWh = 3.6 megajoules.
There is plenty of information out there on the AZD Transit Connect.
Including the fact that it contains a 3KW Brusa charger.
No matter how much larger your EVSE (that is the device on the wall that supplies the AC power) as long as your original is at least 3KW (it is...) then you won't charge any faster.
It would be possible to add more or bigger chargers if your EVSE can handle it.
Check out what MetricMind had done with adding more Brusa's to Nissan Leafs.
kWh stands for kilowatt-hour...
I've seen so many people mess up units of measure that I didn't even notice this one! :D
I assumed that the subject was power (rate of charging), and overlooked the incorrect units.
But also, not that it really matters to clarity of communication, the name of the power unit is "watt" (not a proper noun, so not capitalized). The symbol for the watt is "W" (capital, because typically the symbols for units named after people are capitalized). All of that is just like the joule (symbol J).
Can anyone point to good sources of wiring info or guidance for updating a 3kW charger setup like this? I'm looking at buying an Azure Transit Connect but 3kW charger is really limiting. I could get a lot more use out of it with 7kW or better and the charging network is now there to do longer delivery runs if you can charge during lunch or other break.
I presume nobody has tackled adding DC fast charge to an older vehicle like this? Tell me I'm an idiot if necessary, I haven't done my homework on that idea yet. I presume there's a lot of control feedback required and active cooling and generally big ambitious project... but this is where the big ambitious projecter folk are found so I'm asking.
Nice job TeLLus :eek: You're in Europe I presume, with 3phase everywhere.
How do I buy one of these Transit Connects?
There were only a few hundred built, the last one was built in 2012, and by now they're probably all either scrapped or in the hands of enthusiasts... so look for ads, such as eBay listings? Maybe some fleet still has one being retired, or an enthusiast is moving on to another project.
Wikipedia: Azure Transit Connect Electric
https://en.m.wikipedia.org/wiki/Azure_Transit_Connect_Electric
Here's one in eBay:
https://www.ebay.com/itm/2012-Ford-...356768?hash=item2f3a58bc20:g:lO8AAOSwkqNd57Eb
1 - 11 of 11 Posts
