To keep things short I'm 38yo, I have to use a mobility scooter to get around outside. I have a 4 wheel Golden Avenger (older model) it uses a fwd/rev pot throttle, it's 24 volt and 750 watt motor. It uses SLA batteries. What I'm looking to do is swap the throttle with a twist grip. With the fwd/rev being on the same pot could this be done with a 3 way toggle to swap between fwd/rev or do I need to replace the speed controller, throttle, ect. If I need to replace any suggestions on one with reverse and lock control (keyed switch)
I've already isolated the light system from the main harness and did a LED conversion. Thank you in advance for any assistance. If you need anymore info let me know.
