Fewer cells sounds better, but in practice I don't think that you will be able to get cells that large, at least at a reasonable price. I suggest just parallelling enough cells at the lowest level to reach your desired 400 Ah capacity, then stacking four of those sets in series to get a suitable voltage.
The cheapest source of lithium cells is probably salvaged EV battery packs; however, they may not be the desired chemistry. For RV applications LiFePO4 is often preferred, but it is not commonly used in EVs.
I have considered using Nissan Leaf modules for an RV or travel trailer. A challenge is that they are 2s2p in configuration (33 Ah per cell in the first generation, so 66 Ah and 7.5 volts per module), so they can't be combined in parallel at the cell level unless you also parallel the BMS terminals, and ensure the any current imbalance is not excessive for those smaller terminals. Only two modules would be needed for "12 volts", but a dozen modules would be needed for about the desired capacity - if they were all stacked together that would be a stack sized
11.9" (303 mm) x 8.8" (223 mm) x 16.5" (420 mm)
and 101 lbs (45.6 kgs)
Any of the pouch cell EV batteries using larger modules will be difficult to reconfigure for the desired voltage. The prismatic cells of the German brands should be easier to work with, especially the Sanyo 25 Ah cells originally used in the VW e-Golf (which has since changed to Samsung SDI) because those Samsung cells have threaded terminals (easy to build jumpers and cables). Of course with 25 Ah cells you would need (400/25)x4=64 of them.
Keep in mind that the normal operating voltage of a series set of four lithium cells - even LiFePO4 but especially automotive chemistries - is very high for the nominally 12 volt systems of an RV, and the charging voltage is even higher. You might consider a DC-to-DC regulated power supply (set for no more than 13.2 volts) for at least the more sensitive equipment. I find that furnaces make a lot of noise and may have problems even at common lead-acid charging voltage.
