Normal RV practice for capacities larger than is practical with a single battery is to use two 6V batteries in series, most commonly of the GC2 size simply because deep-cycle batteries in this size are readily and economically available. Yes, some parallel 12V two-battery installations are used (I have one in a trailer), usually to be able to use cheap "RV/marine dual purpose" 12V batteries.Sounds like you might be stuck inside a 12 volt toy box. Last thing in the world you want to do is install Pb batteries in parallel. Guaranteed to cut cycle life in half. That is why battery manufactures suggest parallel installations. Smart money is if you need 500 AH, then buy 500 AH batteries. They will not be 12 volts, they will be 6 or 4 volt batteries wired in series.
This is one way to reduce problems of paralleling, but if you're building a pack from individual cells is that really a problem? Production EVs normally parallel at least two cells at the lowest level, and those using tiny 18650 cells parallel dozens of them at the lowest level.Personally I would go with a higher voltage battery running a DC to DC convertor so I could put a bunch of small cells in series.
Nope.Lithium batteries freeze easily
If you plan to use this battery when the weather drops below 40F you are pretty much stuck with FLA or AGM
If you are comparing LFP to LFP with the same nominal voltage, then you can compare Amp Hour cost.unfortunately that's how LFP cells are usually priced to compare them...
Well I am hear to tell you is it is common practice to run at 24 volts, and a few 48 volt systems. But be warned going to a higher voltage eliminates your prime power source, the 12 volt alternator to recharge your batteries whenever engine is running. Pretty much means you would need a generator.I have considered the idea of a higher-voltage RV battery, but specifically to make 120 V AC integration better in a motorhome:
In fixed solar installations, sure, but in an RV? There are lots of 24 V vehicles (mostly military), but I've never heard of anyone doing that in an RV - do you have links to any RV which comes this way, or a company converting them? I wonder what they use for conversion from battery voltage down to 12 V (nominal).Well I am hear to tell you is it is common practice to run at 24 volts, and a few 48 volt systems. But be warned going to a higher voltage eliminates your prime power source, the 12 volt alternator to recharge your batteries whenever engine is running. Pretty much means you would need a generator.
Sure, but you got caught in a 12 volt box. There are two applications that demand 24 volts and once in a while 48 volts.In fixed solar installations, sure, but in an RV?
OP used a/h so I used it. Sorry it offended you.Completely meaningless.You do NOT PRICE BATTERIES based on AH because it tells you NOTHING. Your base battery cost on Watt Hour Capacity.Not quite $0.85 per amp hour but the cells we have are about $0.875 per amp hour now on eBay:
Which battery cost less?
1. LFP 100 AH cell = $125
2. LMO 100 AH cell = $140
By your logic the LFP cell is less expensive and is dead wrong. The LMO cell is less expensive.
Battery Watt Hour Capacity = Nominal Voltage x Amp Hours
100 AH LFP = 3.2 volts x 100 AH = 320 Watt Hours for 39-cents per WH.
100 AH LMO = 3.8 volts x 100 AH = 380 Watt Hours for 37-cents per WH.
That's a good example of where it would make sense. Those are a tiny fraction of the RV world (I don't think even a normal diesel Class A would be 24 volt).The second application is perhaps something you have over looked. Class A Motor Homes/RV with diesel engines and 24 volt electrical systems. Like a Tour Bus Conversion with all the Bells and Whistles.
Sure, but we're discussing an RV, and one that is unlikely (I would guess) to have a massive solar installation and will almost certainly have a 12 volt automotive charging system. Carrying a generator just because the system wasn't properly set up to charge from the vehicle would be silly, and doing without power is not reasonable.The deal breaker IMO is loosing the engine alternator as a primary power source. However people who use solar have no fear of loosing the alternator. They just use a genny or do without for times of clouds/rain.
24 volt alternators are for vehicles that are 24 volt (military, maybe still some large commercial vehicles). 48 volt? Who knows... I don't know what is used on boats. I checked a random bow thruster manufacturer, and their smaller units are 12 volt while the largest are 24 volt.But for those with some good reason I can't imagine, 24V and even 48V alternators do exist, can be custom wound.
Maybe on a boat using electric propulsion or very big winches, bow thrusters etc
Yes, LFP is the only safe non-lead chemistry for any small space / mobile House bank use case. And new big prismatics, not a science projects of cylindricals or ex-EV banks.I personally would not use LMO (lithium manganese oxide) in an RV
Normal usage to vendor charging specs produces some gassing.It your batteries are gassing excesively would tell you the voltage is set too high
Finally!Last thing in the world you want to do is install Pb batteries in parallel
$400 for local pickup Deka GCs, gets more AH, and plenty left over for a top-notch 40A marine charger, panel kit and a genny.You can buy a 24 Volt , 200 AH battery pack with a steel case and built in charger (Standard battery pack for electric pallet jacks) for about $2000 if you go with lead
Any idea of the actual maker?Not quite $0.85 per amp hour but the cells we have are about $0.875 per amp hour now on eBay
https://www.ebay.com/itm/Lot-of-8-p...377409?hash=item2ab7fc1501:g:NAcAAOSwaB5Xtx0m
From top-notch vendors, makers likeHow many cycles are the LiFePO4 cells expected to last?
