I’ve already stated “why” for AGM.
OK, not going to re-readI’ve already stated “why” for AGM.
Some of the air conditioners for trucks run on 120 VAC anyway, and are installed with a dedicated inverter, so the only benefit of higher voltage is smaller cable. Of course in a 24 volt vehicle, 24 volt air conditioning would make sense. Similarly, in a facility where 48 volts is used for other purposes, 48 volts would make sense for air conditioning.Brian I think you are overlooking some things. 24 and 48 volt super high efficiency air conditioners like Truckers, Off-Griders and Telecom use. I agree with your POV. If all you need is lighting, some entertainment like a TV/Radio/AV and low power devices 12 volts is just fine. But you have people who insist on electric cooking, refrigeration, and the impossible air conditioning requires a lot of power that a 12 volts is just not capable of doing safely, efficiently, and economically.
When you say automakers and AGM, you mean Starter batts right? Totally separate market, little to do with deep cycling batts suitable for House bank usageThere seems to be three choices for batteries. FLA, AGM, and flavors of lithium.
Automakers are already switching to AGM. Lithium isn’t readily available in high capacity cells.
Nothing.What do you want to know?
Let's stick to creating a 400AH lifepo4 house battery for this forum.
Any discussion of the needs which this battery is to address clearly are off-topic, although discussion of non-lithium solutions is apparently now okay.Correction. Topic is:
400AH lithium cells? Best price per AH? $0.85/ AH?
Only a few posts addressed the topic.
1. refrigerator (40 watts)I need a battery that supports my future camper van electrical needs/requirements as follows...
Even the smallest available microwave oven has power demand comparable to the air conditioner. As long as there are not multiple large appliances, or they are not run in combination with the water heater or air conditioner, current and power demands should still be non-issues for this size of battery at 12 volts.I still have to source an efficient microwave that will still pop popcorn.![]()
In a thread of 90 posts, sportcoupe has not mentioned the endurance required, or how frequently driving or starting the van or other engine as a generator might be acceptable, so there is no way to determine whether another charging source such as solar is required. All we know is that 140 A @ 12 V (nominal) is available for charging (and a rational person might guess that's the van's alternator). Since the total capacity of the battery bank is a fixed requirement, and the charging source doesn't change the battery choice, I don't see any relevance to a discussion of a solar system or whether it is required.... And LFP will eliminate the need for solar.
In a thread of 90 posts, sportcoupe has not mentioned the endurance required, or how frequently driving or starting the van or other engine as a generator might be acceptable, so there is no way to determine whether another charging source such as solar is required. All we know is that 140 A @ 12 V (nominal) is available for charging (and a rational person might guess that's the van's alternator). Since the total capacity of the battery bank is a fixed requirement, and the charging source doesn't change the battery choice, I don't see any relevance to a discussion of a solar system or why it is required.
Because solar is only **necessary** with lead, assuming shore power not often convenient.I don't see any relevance to a discussion of a solar system or whether it is required.
You will need a genny to run the aircon.Daily driving with occasional stops of 2-3 days. Starting ICE engine 220A alternator is perfectly acceptable to charge house battery. I have a 140A smart battery isolator to charge if it would be suitable to the house battery.
Chinese knockoffs much cheaper, can buy a second for spares.Heater might be a Webasto gasoline air top heater unless I find something more cost effective.
Yes.current and power demands should still be non-issues for this size of battery at 12 volts.
