Note all the isolator (combiner / VSR) does is stop Starter from going flat, nothing to change the charging.Besides fuel consumption, what's the difference if I run a small 1000W/800W genny running an inverter/charger or the ICE engine with electronic battery isolator charging house battery?
Well you can wait for guesses or calculate it yourself pretty easily. Most of the AGM batteries you are interested in specify Internal Resistance. For example a Fullriver DC400-6; a 6-volt 400 AH AGM specifies Ri = .0016 Ohms. It would take 2 in series for 12 volts thus total Ri = 2 x .0016 Ohms = .0032 Ohms.1. Voltage sag under load falsely hitting low voltage cutoff on inverter reducing house battery usage, even with a fully charged battery. Especially apparent if running microwave or aircon. This wouldn't happen using LFP pack as lithium doesn't experience voltage sag nearly as bad.
Yes. Counteracted by going bigger AH capacity.Voltage sag under load falsely hitting low voltage cutoff on inverter reducing house battery usage, even with a fully charged battery. Especially apparent if running microwave or aircon. This wouldn't happen using LFP pack as lithium doesn't experience voltage sag nearly as bad.
Nope, all three get many times greater lifetime by cycling more shallow.400Ah AGM and LFP can both be discharged 80% without greatly reducing cycles.
With this small air conditioner, I agree.The "challenge" with aircon is not the current, but the kwh per day consumption.
Thanks for the handy chart.sportecoupe one more design tip. Be real careful with On-Line Wire Size Calculators. They will get you in trouble real quick.
LFP Ri is double some AGM batteries. I didn't expect that.FWIW broaden your horizons. Go look at one of the 400 AH LFP cells. Just about all of them will list Ri. For 12 volts you would need 4 in series. So multiply the Ri by 4 and tell me if it is higher or lower than the 400 AH AGM. What you are going to gain from that will surprise you because it will be exact opposite of what you are expecting. It will tell you which battery has the higher Specific Power which is expressed as Watts / Kilogram. Put another way how high a C-Rate the battery is capable of. So go see what you find, and tell me what you think.
Bigger Ah - ok more is better, two Lifeline 6V 400Ah AGM should be fine for voltage sag.Yes. Counteracted by going bigger AH capacity.
AGM's can be mounted sideways under van. So can LFP
Nope, apparently reduces lifetime, but depends on maker. Risky at least.
current and power demands should still be non-issues for this size of battery at 12 volts.
Aircon use on batteries will be limited. Max 2 hours a day (maybe?).Yes.
I tried to tell you that in PM's but you were not having any part of AGM out performing LFP. Amp Hour per Amp Hour, AGM out performs Lithium with respect to high current. I had to have you discover it for yourself. The math does not lie.LFP Ri is double some AGM batteries. I didn't expect that.![]()
They cannot and is of no concern for scum bag spammer. LiPo is the last thing you want for a house battery or any application requiring long life as LiPo only have roughly 100 cycles in them. LiPo's are used in RC aircraft where C-Rates run 20C or greater continuous. Extremely dangerous lithium batteries notorious for catching fire.If LiPo, how can they be made to work at 12V for a House bank?
