1 - 1 of 1 Posts
Discussion Starter #1
40A 9.6kW Level 2 Deluxe OpenEVSE Waterproof Outdoor Charging Station For Sale
I bought a 2013 Nissan LEAF and love it! I have a heavy electrical background and was inspired when I saw some DIY units for sale here. Work has been very slow and my employer is now months behind in paying the other employee and I. :cry: This has caused a severe financial hardship. It's a very stressful time with 2 little boys. I need to support my family anyway I can and am hoping to build and sell a few EVSE's. Thanks for reading this, Now on to the fun stuff!!
I have a Deluxe 40A 9.6kW OpenEVSE for sale with a Custom 40A J1772 25 foot cable using a 63A plug. 40A 4ft. Power input cable with 14-50 plug. 50A high current contactor. This unit operates at Level 2 on 240VAC. This is mounted in a PolyCase Polycarbonate Enclosure with Clear Cover - NEMA Rated for outdoor use. This unit requires a 50A 240V circuit with a NEMA 14-50 outlet for full 40A potential. However you can dial it back to whatever you have for a supply like a 30A dryer outlet, see below.
The cost is $420 plus $25 for UPS ground shipping in the continental USA
Also available in 45A 10.8kW version for $13 more. (input cable: 50A, J Whip: 45A w/63A Plug, all else the same)
It will charge any J1772 compliant car at up to 40A
The EVSE may be set in multiple steps on Level 2.
Level 2: 6,8,10,12,14,16,18,20,22,24,26,28,30,32,34,36,38,40A
This advertises the available current to the EV which intern draws what it is designed for. You can go into the menu and set it for less if you take the EVSE on the road with you to fit what you may find in the wild.
I can now customize the firmware to whatever values you like before shipping. I chose these values to give the user flexibility for various outlets found in the wild. I stop at 40A as this is what the cables are rated for. This unit is constructed with 40A components except for the contactor which is 50A. It is designed to plug into a 14-50 outlet protected by a 50A circuit breaker. 40A is 80% of 50A and it is the maximum allowed for the homes outlet as a continuous load.
Case Specs:
Case measures 7.63 x 4.63 x 3.09 in.
Designed to IP65 of IEC 529 and NEMA 1, 2, 4, 4x, 12 and 13 specifications
Silicone rubber gasket makes this ideal for outdoor use in a wide range of adverse conditions
Molded on surface-mounting flanges
Captive, stainless steel screws thread into brass inserts for cover on/cover off applications
UL Listed to UL508-4x specifications (File E194432)
Main Board Specs:
Open Source - Hardware (Creative Commons 3.0 BY-SA) and Firmware (GNU GPL v3)
Fully supports SAE J1772 Recommended Practice
Software adjustable pilot (6A – 40A)
4W Switch Mode Power Supply Integrated
Built in GFCI with 20ma trip point
Supports all J1772 states including “ventilation required”
Supports Diode check
AC L1 – L2 auto detect Current setting for each (only L2 available on this build)
Ground verification and Stuck Relay detection
Specs:
OpenEVSE v.2.5Plus board running newest firmware
All nuts/bolts/washers are STAINLESS STEEL
The base plate inside is 1/4" thick high quality plexigalss, no thin stuff here.
25ft. Custom 40A J1772 “Whip” with 63A high current plug and PET braided sleeving.
The contactor is a quality 50A 240v unit
The input cable is 40A 4ft. 8ga. with the popular NEMA 14-50 plug. This is the one all the Tesla guys have installed as well as the standard at RV parks!
You can even use the PlugShare app and set the filters to include NEMA 14-50 and see all of them in the country, there are a surprising number of them.
It has a monochrome blue display
I used a metal blue lighted ring Menu/Select button. With IP65 water resistance rating
Heat shrink tubing used throughout.
All parts are new.
Here is a link to the owner’s manual:
https://code.google.com/p/open-evse/wiki/Users_Guide
If you would like the unit customized with a twist lock plug for example or something other than the NEMA 14-50 plug I can do that for the difference in parts. In the case of a L6-30 it's no charge and would allow you to use many adapters. I also build custom adapters, see my other thread.
If you would like to see it in action on your EV we can arrange that thru private message at my home. Local pickup in Las Vegas near Smith's grocery on East Flamingo. Payment is by PayPal if shipped or cash for local pickup.
I worked hard on a nice PDF featuring some of the EVSE's I build and accessories. Check it out here:
https://www.dropbox.com/s/hc6ei1dkkqwbiwz/BSAelectronics EVSE flyer.pdf?dl=0
I get a lot of inquires about custom builds. YES I definitely take orders for anything you would like to see in your EVSE. Lead time is only 3 days. Example I can build this one here for the same price and make the Whip longer starting at 25ft add just $1.20/ft up to 50ft. Private message me or if you have a general question you think the rest of the community can benefit from post it here.
LEGAL DISCLAIMER: Because of lawyers I have to add this. This EVSE is intended for use ONLY by responsible adults. Because they are hand-made, they are not UL listed - but are made from UL listed parts. 240v electricity is serious business and caution should be exercised while using any EVSE. For safety's sake, do not use this EVSE outdoors in inclement weather unless it is a model that specifically says Outdoor or Waterproof. You should always install a GFCI breaker not a standard one for any and all circuits a person can come in contact with This EVSE has a GFCI built inside that protects from that point down line. (The J plug side of the EVSE is safe for outdoors in all weather). BY PLACING AN ORDER WITH US, YOU ASSUME ALL RISK ASSOCIATED WITH USING THIS EVSE AND AGREE THAT WE ARE NOT LIABLE FOR ANY DAMAGE THAT MAY RESULT FROM THEIR USE.
1 - 1 of 1 Posts
