Hi - does anyone know where I can get a 48V (16s) 150+A BMS? I need one asap, and if you have one lying-around, I would love to buy, or replace it with a better one.
Thanks,
Thanks,
Thanks,
I have leftover Elithion BMS gear could easily cover 16s battery and is well documented online. I have a BMS Master pro and slaves with end boards could make it into single or double string as needed. Can send photos.Hi - does anyone know where I can get a 48V (16s) 150+A BMS? I need one asap, and if you have one lying-around, I would love to buy, or replace it with a better one.
Thanks,
Hi, sorry for the delay. That sounds a bit-much for my needs, but thanks for taking the time.I have leftover Elithion BMS gear could easily cover 16s battery and is well documented online. I have a BMS Master pro and slaves with end boards could make it into single or double string as needed. Can send photos.
Steve
