1 - 4 of 4 Posts
Just because you can doesn't mean you should.
Are the motors mechanically locked or is this a genius scheme to eliminate a diff?
The obvious answer is that the motors are mechanically separate and using one motor per wheel is the scheme. To be "genius", it would need to split torque by some adequately suitable method and would need to account for one wheel losing grip.
1 - 4 of 4 Posts
