1 - 9 of 9 Posts
Hi there folks, just thought I'd share a quick video we put together at the shop where I work of our first 62kwh Nissan LEAF swap. We ended up doing the swap on a 2012 Nissan LEAF, which does involve some compromises, and is not quite as easy as it would be on a 2013 or newer LEAF, but overall it seems to be working pretty good so far!
Isn't it possible to split the packs apart and replace the batteries from one to the other? Meaning you'd put the new batteries in the old battery casing and using the bms/wires from the original battery pack.
You can probably physically do that between any two packs of the 24 kWh, 30 kWh, and 40 kWh capacities, because they use the same number of the same size and shape of modules. The 62 kWh pack uses modules which are very different in size and shape, and the total size of modules is larger so the case is deeper - there's no way to put the modules from the 62 kWh battery into the earlier or lower-capacity cases.
Even if the new modules would physically fit, their BMS wiring will be different. Even between the old modules (24 kWh, 30 kWh, and 40 kWh), the BMS wiring might work but the BMS programming could be confused by the change in capacity... but the real issue is the module size and shape.
1 - 9 of 9 Posts
