Hello, I started planning a conversion of a 70’s Chevy Eldorado convertible, and wanted to ask a few dumb questions please:
1. This car weights 4700lbs as-is, and probably 3000lbs after the original engine, gas tank etc will be removed. What is the minimal size of motor and voltage that are recommended here? How do you calculate it?
2. For a decent range of 200 miles, what is the battery capacity that is calculated?
3. I assume that I leave the transmission, correct? If so, do I need to lock it on a certain gear, or do I just leave it as-is?
Thanks for helping me here!
