I understand your desire for a long-range, but consider having half of your 300-mile range and invest time into adding fast charging.
Even on a sedan, 300 miles would require 120.00 kWh of batteries.
At the current battery prices right now ($150.00/kWh optimistically) your pack would cost $18,000.
One of the best energy densities available at the moment is Tesla Model X modules, which are ~11 pounds per kWh, your pack would also weigh 1,320 pounds.
I also need a similar amount of range, however. I want to see loved ones 300 miles away. What is the solution? Fast charging!
There are public fast charging stations popping up everywhere that allow you to charge super quickly. Instead of plugging in your car overnight, you can charge a 50kWh battery pack in just 20-40 minutes. I would rather save $10,000 and stop for a cup of coffee halfway through my drive while carrying half the weight.
There are two ways of achieving fast charging at the moment, CHAdeMO (CHArge de MOve) and CCS (Combined Charging System).
CHAdeMO is supposedly easier to set up, although Damien Maguire (amazing dude) has been selling kits to hack a charge controller out of another car to make it happen, although that is what I have been focused on and I can tell you it's quite technical.
You will see a lot of advice online saying that your car must be light and aerodynamic. While that will make your car more efficient, you will find that most of that advice is from 10 or so years ago, as batteries were much bigger and much more expensive. So it was even more important then to make the most out of your kWh, as you couldn't fit many in the car.
Beautiful car btw!
Good luck.
Beautiful car btw!
Good luck.
