So if we eliminate the possibility of two 2-speed gearboxes, then in order to have two rear motors, the following architectures remain:
a) Different reduction ratios + rear (and front) differential. The Model 3 reduction ratio is close to 10. So for the R2, it would be 14 on one motor and 7 on the other motor. A further twist here is that if the 14 motor could be disengaged by a clutch, then the ratios could be wider such as 16 and 6. The front ratio would remain at 10.
b) Another possibility is just one 2-speed gearbox in the rear for one of the motors. One motor runs at ratio 14 the other at 7 but also has the benefit of the 2-speed gearbox and then can also run at 14, for low-speed high acceleration. I don't think this would be a good design.
